oil pump banjo bolts
paulbellefleur
Post by paulbellefleur »
Does anyone know where I can get the banjo bolts that join the oil line from the tank to the pump? Both of mine are broken.
650hardtail
Country: usa
Suzuki 2-Strokes: 1972 kawasaki h2 750 1972 kawasaki s2 350
Re: oil pump banjo bolts
Post by 650hardtail »
for what bike ??? and welcome
If its the push-on type of banjo fitting you are after I'd guess you have a GT triple. Those are still available from your dealer but they have to be ordered.
Allan, I thought he said the bolts, but are you saying that it's possible to buy the check valves from Suzuki to put into the oil feed pipes? That I did not know.
Oh I'm sorry Richard, I got fixated on the banjo part in my first reply. The bolts and the banjos for the CCI tank line to the pump are still available.
There are two types of banjo fitting, one with no barbs and one with two barbs on the pipe extension. These are the ones found on the radiator/expansion tank tube and oil pump hose to CCI tank I'm referring to.
