Electronic tacho
Posted: Mon Mar 02, 2009 12:06 am
This post is not asking about new aftermarket tachos but addresses electronic tachos that we tightwads bought or acquired cheaply and wish to use on our modified bikes.
So a triple fires once per cylinder per revolution. Nothing strange about that.
And most in line 4 fours strokes pre-2000 or so had two double ended coils that also fired once per revolution. the same applies to an RGV250 which has two pickups and two coils, each of which fires once per revolution.
So far so good. So any tacho for an inline four 4 stroke or V twin 2 stroke will probably work fine on a triple or even a twin two stroke. That's good news for people running points or a 12v Dyna system, but does not apply necessarily to CDI or magneto ignitions.
If the bike has a pickup per cylinder, one of the above tachos will work, but if the ignition fires twice (or more) per revolution, the tacho will over read by 2:1 or more.
There's an RZ350 on the net that used an R1 tacho and for the life of me I can't work out how he made that work. One is 2 pulses per rev and the other is one per. Anyone got any idea how that worked?
A Polaris 2 pulse tacho would work with a twin firing twice per revolution I thinlk, but 6 pulse tachos won't be close.
