BS40 Float adjustment?
Posted: Sat Apr 20, 2013 6:46 pm
by T350guy
Just picked up a 74 GT750.
According to Clymer you turn the carb upside down to check float height ( 27.5mm) . This way it reads 23mm. If I turn carb slightly until float just rest on needle then I get 28mm.
Which way is the correct procedure.
Re: BS40 Float adjustment?
Posted: Sat Apr 20, 2013 9:03 pm
As you correctly surmised, The carbs should be at an angle to set the float height. If your measure 28mm, they should be fine.
Posted: Sat Apr 20, 2013 9:49 pm
by pearljam724
If your reading 23 mm the needle is being depressed with carbs upside down. Regardless of which way you turn them, it needs to read 27-28 mm when the tongue is barely touching the needle. And the needle not being depressed. You actually have to turn the carbs close to a 45 degree. If your manual states it needs to read 23 mm with the needle completely depressed, then that would be fine. If not, ignore that measurement and shoot for the other.
Posted: Sun Apr 21, 2013 10:54 am
by T350guy
Thanks guys..Floats were right on with tab just touching needle.
