Brand new Mikuni VM32 in '72 T500
Posted: Tue Jan 08, 2013 1:41 am
I thought I could just use these carbs out of the box. After reading a few threads I found out I needed to use a 120 main jet to go along with my Titan Performance expansion chambers and pod air filters. But is that the case for the new VM32 carbs or only if you are running stock carbs?
What other changes should I make on these carbs? I've read the carb settings from Ozebook but I don't think they pertain to these brand new carbs... Oze says the float height should be at 27.3mm but I believe my new VM32's are more like 22-24mm float height??
Purchased new from Dime City: http://www.dimecitycycles.com/vintage-c ... 1-028.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Out of the box jetting:
200 Main
35 Pilot
6DP17 Jet Needle
2.0 Air Jet
159 Q-6 Needle Jet
I can tell you this I am using 120 main jet and the right cylinder wasn't firing strong... only a little exhaust was coming out of the pipe. I put my hand a few inches away from the right cylinder exhaust and it was quickly covered in wet gas/oil mixture... I check my points and set timing... cut 1/2" off the spark plug cable and now it seems to be firing better. I get spark from both plugs. but had no idea it would get that wet coming out of the back of the exhaust chambers. While I was working on the bike, letting it idle, that wet gas/oil mixture would just drip out of he down pipes. Any ideas?
I don't really now why I wanted to get the new carbs... It was just one of those late night purchases you don't think much about and wake-up asking yourself "did I really just buy that?".
200 Main
35 Pilot
6DP17 Jet Needle
2.0 Air Jet
159 Q-6 Needle Jet
