new vm32 carbs off amazon?
Posted: Wed Oct 03, 2012 1:54 am
by MikGsxr
Hi all, my stock 1974 t500 carbs probably need a rebuild, would it be easier and more cost effective to just get these instead? what would i need to do to make them work on a 1974 t500 with stock airbox and stock exhaust? would they go right on? what tuning would have to be done? thanks!
http://www.amazon.com/Mikuni-Standard-V ... =vm32+carb" onclick="window.open(this.href);return false;
Re: new vm32 carbs off amazon?
Posted: Wed Oct 03, 2012 11:12 am
by titan performance
That looks like a flat slide !
Posted: Wed Oct 03, 2012 12:46 pm
It's just a simple aluminum bodied VM32. It's jetted differently and I don't think that stock jets will work in that carb. They will physically fit but will need to be set by trial and error.
Some Suzuki OEM Mikuni crabs were what they called homopressure and that means that the float bowls are vented to the intake mouth to change the fuel slope. If your are like that you may have to try different air jets to toip teh fuel slope.
Posted: Wed Oct 03, 2012 4:28 pm
by MikGsxr
bugger, so I guess rebuilding the stock ones is the only way to go?
Posted: Wed Oct 03, 2012 4:39 pm
Actually, I suspect that if your carbs are worn out, a new set of Aluminum bodied carbs might be a nice improvement, but you will have to jet them accordingly and of course if you are going to replace them, maybe sir might like to consider 34mm instead.
Posted: Wed Oct 03, 2012 7:57 pm
by MikGsxr
TZ- thanks, good idea but my problem is that I know nothing about jetting or setting up carbs. lol
Posted: Wed Oct 03, 2012 9:55 pm
by elbert
titan performance wrote:That looks like a flat slide !
Yeah, first time I looked at the link there was a picture of a standard VM carb but now there is a picture of a flatslide ????
