Lightened alternator GT750 (and other crank lightning stuff)
I'm considering lightening my rotor for the GT750 project to increase acceleration, de-acceleration.
Anybody ever done this?
Did you mutz about with this Watercooled?
I've got a couple of them, so I imagine I'll lighten one a spot and then see if I like it, if I don't it's a super easy part to switch out.
What do you think?
Thanks - Arne
http://www.practicalmachinist.com/vb/sh ... p?t=158836
What do you think?
Thanks - Arne
1981 Honda CB750-1000 driver
1982 Honda GL500 easy project
Arne just where on it are you planning to lighten the rotor,
Inside the perimeter of the electromagnet poles and around the left and right flat faces.Suzsmokeyallan wrote:Arne just where on it are you planning to lighten the rotor,
Well, the whole rotor weighs like three pounds. I'll try for a pound, which is 3.53 square inches.... I think I can get that much steel out of it.Barry S. wrote:The crank weighs a ton, I doubt you would notice much difference unless you could shave a pound or two.
I guess we'll see! Arne
- water cooled
Alternator Rotor
Sorry Arne,
I decided to pull the entire rotor and remove the rest of the alternator completely. I only need a couple minutes of operation for each pass so an alternator is not in the cards for me.
However, I think SuzukiDave may have done a lot in this area. He focused on a Polaris charging system I think.
I like your approach. Every ounce you can get off the end of that shaft makes a difference. I just finished the left side (starter clutch assembly).
Good luck Arne and keep posting pics...its great to see your progress.
Kevin
Kevin
Kevin,
Now you're talking. Who needs an electric foot anyway. Throw out the starter, solenoid, wiring, push button, drive gear pair, clutch assembly and then cut down the crank gear and what's left of the clutch hub. You might be amazed how much weight is hiding there.
Arne,
Replace the two front disks with something modern and save about 8-10 pounds of unsprung weight. For ideas, try here:
http://pinkpossum.com/GT750/phattrakka2/p5brakes.htm
Arne,
- water cooled
Richard,
Got all that done two weekends ago. Thanks for the pics of the starter clutch hub you posted. I didnt cut mine down to the extent you did, but certainly removed a lot of material and weight off the starter clutch hub.
I also removed the breaker cam bearings and sized the smaller bearing OD. Looks like a 35mm freeze plug (wlesch plug) fits nicely to block off the oil path to the breaker housing. Bought the freeze plug from NAPA for $1.45. Should to the trick/.
Because i didnt need the added width of the points side any more i trimmed my cover back and then made a nice cover plate .
Suzukidave wrote:Because i didnt need the added width of the poibts side any more i trimmed my cover back and then made a nice cover plate .
Did you cut off the end of your crank? Perhaps you have a photo of that somewhere? Thanks, Arne
No , everything is still on the end of the crank includeing the starter clutch . I really could have made the cover even shorter without any problems but i wanted the engine to stick out the sides of the frame about the same amount just for looks plus the Phat pipes are going to ground before the engine side covers ever doArne wrote:Suzukidave wrote:Because i didnt need the added width of the poibts side any more i trimmed my cover back and then made a nice cover plate .
- water cooled
