the owner said that the bikes were much improved buy his addition of home made velo stacks .
these were made out of plastic plumbing elbows.
so i decided to make some and see if i could get the same improvement.
all went to plan but was disapointed in the result,
marginal at improvement best.
i think because the kwakas are in higher state of tune the differance is more noticable.
which got me thinking about skiming the head to up the comp ratio a bit.
as the comp when i rebuilt the motor was only about 115/120.
which brings me to the real subject of this thread.
when i rebuilt the motor i used "cruzin image" pistons .
no probs sofar with them but i read on the kwaka forum that some of there members found that the position of the wrist pins relative to the crown and skirts was about 1 mm out resulting in low comp and affecting port timming.
has anyone on this forum measured them in respect to the oem pistons.
it never occured to me to measure the against the oems before fitting.
cheers mark
