Super shim lift port timing LOL
Posted: Thu Nov 26, 2009 9:06 am
by Suzukidave
Posted: Thu Nov 26, 2009 9:12 am
by Craig380
There was an old tuning theory that said "if a motor will take a high compression ratio, it isn't breathing deeply enough" ....
Posted: Thu Nov 26, 2009 10:25 am
by Buffalo-guy
Well, I don't know about this Dave. It may work, but I suspect it might be a bit peaky
Are there enough base gaskets in existance to seal all the plates? You would have to mill so much off the block, that maybe all you need is the head.
Interesting concept, but you go first. Where the heck did all those lift plates come from? Cheers.
Fred
Posted: Thu Nov 26, 2009 10:57 am
by Suzukidave
Fred , it was a picture sent to the list years ago i saved and just ran across .. i thought it would be a funny topic just to see what you clever guys come up with
Posted: Thu Nov 26, 2009 2:24 pm
by Tom Garcia
Hmmm.... That much lift! Bet it really comes on the pipe at about 30k RPM....
Dave - I still have your copper head gasket patiently waiting to be placed into service....
Posted: Fri Nov 27, 2009 11:13 pm
by Suzukidave
Yeah .. i think i need a longer stroke .. that's what she said
Posted: Sat Nov 28, 2009 7:56 am
by Frank
Actually, you might be on to something! You could build your entire cylinder out of individual pieces all stuck together. Imagine how easy it would be to change porting: just swap out a few thin pieces here and there to see how it worked! It'd be even easier if you made them out of cardboard, just cut with an exacto knife or similar... No need to worry about piston sealing either: just make the cylinder holes size-on-size and the rings would slice away anything in the way! Dayum!
Posted: Sat Nov 28, 2009 8:34 am
by Zook-e
Kind of a "SuperTrapp" type tuning kit for the GT!!!
