GT750 reed intake idea's
Tom Garcia wrote:Dave - I see you engineered in water injection for the vertical 8-petal design.... :D :D :D :D .
:lol: The plan is to machine farther down till i have a flat surface to attach the reed block to .
Stage 1 of Kris's TR project reeded cylinder Image
Know of a good CnC machinist as this is what we need , some bolt on boxes for the Arctic Cat reeds Image
water cooled
Post by water cooled »
Dave,
That's a sharp looking reed box...where did you find that? That doesnt look like one you cut off the Arctic Cat...
Just curious.....:roll:
Kevin , i grabbed that picture off the Kawasaki list . One of the guys over there makes up a very nice kit for the H2 750 ..This reed box mounting is just what Teaser was taking about now we just need a good CnC machinist that works for peanuts :~) Image
Here with the Arctic Cat type 6 petal reeds with the window cut piston for true 360 deg intake and to feed the boost ports Image
Here is a sequence of pictures showing how reed boxes can be made starting with square tube . This was done by the cleaver fellow that did the 400 Kawasaki mod . Image
He then figured what the profile of the box needed to be to fit the reeds . Image
And then cut the tubes to fit the reed angles . Image
Then cut mounting plates to attach to the tubes . Image
And the finished boxes mounted up , these type boxes should be able to be fitted up to many of the Suzuki models this same way . Image
