GT750 reed intake idea's
johnakay
I likes them jubblies
Suzuki 2-Strokes: bike
Post by johnakay »
ya a very clever man Dave.
pikeslayer
Post by pikeslayer »
Any idea how much more power or torque could be expected with this mod?
1976 GT750
yes 8) :roll: :wink:
water cooled
Post by water cooled »
The reeds wont necessarily increase torque or Hp. The reeds will basically allow for more radical porting and prevent air/fuel mixture from getting spit back out the carb on the down stroke.
Tom Garcia is doing something similar on his GT250.
Tom Garcia
Country: USofA
Post by Tom Garcia »
I did bring my "kiln" up to Ohio... Some "modern" transfer port, reed intake, and straight exhaust plugs with three sleeves....and a large crucible of molten aluminum...
At least for drag racing, is a water jacket that will stand up to city stop and go traffic in an Arizona summer really needed? :shock: :shock: :shock:
Kevin,
Did you notice the oblique reference there to modern transfer ports in Tom's post. That's where the potential HP comes from - additional port area and ports pointing in a different direction to aid scavenging.
And maybe a tiny radiator and no water pump might be a suitable compromise.
Tom , i also dont really know about that myself but i do know the water cooling allows a tighter piston / bore clearance .
I think Tom is questioning whether or not a smaller radiator might not suffice on a drag bike. Maybe a small radiator from a dirt bike might work for the short runs on the strip.
That would work for sure as i have a smaller and lighter radiator off a V65 Honda Sabre on my Yellow bike and it keeps things cool enough till i get in stop and go traffic and then the fan comes on . so for a drag run i can see a even smaller radiator working like off a dirt bike . http://cgi.ebay.com/ebaymotors/1991-CR5 ... ccessories
water cooled
I have been trying out several different smaller radiator models from dirt bikes recently...so far, I like the KX60 which might get mounted on the RH frame down rails with revised brackets and modified engine inlet and outlet tubes to match the radiator. Then, I can get rid of the heavy radiator mounting lugs and use tabs welded to the frame rail.
I agree about the weight of the GT lower triple clamp...very heavy and it is on its way out. I am working on a viable replacement that will also allow smaller fork tubes. I have some parts coming this week and will have a much better idea if I am on the right track.
Tom Garcia
Country: USofA
tz375 wrote:yes 8) :roll: :wink:
LMFAO!!!!
durgam
Post by durgam »
Im kind of interested in making some reed blocks. Ive got an early 72 motor with the studded head. And it so happens that im a CNC machinist. Ive made some rear sets and other various bits for bikes for a while. Ive also got good 3d modeling software at my disposal. I just dont have the knowledge of port timing and reed cages that you guys do. I would be more than willing to work with you and try this idea out further.
Novice rider,
Professional machinist,
Amature porn star.
pjmcburney
Post by pjmcburney »
I'm not trying to hijack this thread, but...
Durgam, your signature is (perhaps) unintentionally amusing -
Novice rider,
Amature porn star.
So does this mean you get paid/filmed having sex with older partners, or that you're just more experienced than most? :wink:
The correct spelling is 'amateur' (if that is the intention 8) )
Paul
rbond
Post by rbond »
I think his sexual escapades (?) should be left to the imagination. It provides a slight entertainment factor from his posts... :?
