Archived Posts
- Supreme UFOB
Mighty Buffalo Update
I did some work on the front end this evening. I made some mounts for the gauges and tried to figure out what I'm going to do about the headlight. I don't think the headlight sticks out far enough. I'd like the headlight to be another inch or so further forward. What do you think?
OK, somebody refresh me on how to upload photos, please. I just don't seem to be smart enough to make this happen.
- Supreme UFOB
Ogri,
Much better - I can see!!!
It's looking good! What's the rear swingarm from?
The '78 GS1000 on through the 1100's used an 8" headlight versus the 7" one on the GT750 as H2RTuner mentioned. Of course the stock headlight might look a little more right by moving it out an inch or two with a pair of aluminum triangles. You could also try Fang's method and use two 5" chrome lights as he did on his T350. Or you could go for broke with a pair of 7" chrome "off-road" truck lights in true hooligan style!
Jim
Jim
- Supreme UFOB
Yup, it is the stock headlight. I was thinking of the GS1100E head light as well. That 8' light would look great on there. The next problem is finding one. I have done a little searching for one in the past with no results. I guess I'll keep searching Ebay.
I think I can lower the gauges a little bit without fouling anything. With the headlight so close to the headstock there is not much room there.
The swingarm is off of a GSXR 750. I really wanted to use the ZRX swinger but the cost was too great. I would have had to do a bunch of cutting to either the frame or the swingarm to get it to work and even then it would not have been a clean look like it would like for it to be. This swingarm will fit with some minor machining to narrow it by a little less than 2mm.
- Supreme UFOB
I secured an 8" headlight today. Hopefully, I'll have it to fit it up by Thanksgiving weekend. I'm pretty stoked. I think it will look really good on there.
I have a bead on another GT750 in an effort to help me figure out how to wire this thing back up too. If it falls through, I may need some help figuring this out.
On the other hand, I am contemplating adding some extra bracing to the frame to help reduce some of the flex. Also, I have heard that the USD fork will put more stress on the steering head. Does that make sense to anyone. Why would it matter if the fork is conventional or USD? The forces are coming from the same place. I don't get that one.
- Supreme UFOB
The Upside-down forks are much stiffer. Since they don't flex as much as the originals, it may be a little harder on the frame. I'm not sure it would be significant on the street.
If I were bracing the frame, I'd reweld all the joints at the swingarm mounts. It's a big plate on both sides with minimal weld. I think it is a major flex-point.
- Supreme UFOB
I thought about the brakes. Origionally, the plan was to put Tokico 6 pot calipers on the front, but I have changed those for 4 pot calipers from my Triumph Daytona. Between those two, I'm sure it isn't going to make a whole lot of difference. They are both too much.
To stiffen the frame and help to brace for the new loads, I thought I would do something similar to what the guys on the GS and Katana sites do....
This is from the OldSkoolSuzuki site http://oldskoolsuzuki.info/ :
I will not be able to do the A or C brace, but BDEF and then I'll beef up the joints at the swingarm like Lane suggested.
- Supreme UFOB
There are some mods on this page that i guess you could try:
http://www.t20suzuki.com/racing.htm
