Gt500 ignition on the T500
Posted: Tue Oct 24, 2023 8:45 am
by kall399
So I thought I might fit the Gt500 ignition system to my T500 I just need to know if the crankshaft ends are the same
Re: Gt500 ignition on the T500
Posted: Tue Oct 24, 2023 1:57 pm
by karl pa
As far as I know the 2 crankshafts are different, they have different part numbers for the left end. The T500 rotor is held on by a bolt into the crank, and the GT500 flywheel is held onto the crank by a nut.
Can you make it fit ? I don't know.
All the trouble I had with the GT500 ignition I would not go that route. If you need electronic ignition I would look for T500 options.
Posted: Tue Oct 24, 2023 2:03 pm
by kall399
yeah I saw that on pictures I wonder if the taper is the same, if so then it's easy
Posted: Wed Oct 25, 2023 5:49 am
The T500 & GT500 crankshafts are different.
The T500 crank uses a bolt to attach the alternator/ignition bits.
The GT500 crank uses a nut to attach the alternator/PEI bits.
The T500 & GT500 crankcases are also different.
The T500 alternator has the rotor inside the stator.
The GT500 alternator has the stator inside the rotor.
Posted: Wed Oct 25, 2023 12:35 pm
by kall399
Ok yeah thanks
So any recommendations for a complete new charging ignition setup for the T500
Posted: Thu Oct 26, 2023 11:28 am
PowerDynamo / VAPE is an expensive solution that replaces the alternator & ignition.
https://www.powerdynamo.biz/eng/partner.htm
https://www.powerdynamo.biz/deu/systems ... suzuki.php
The T500 stock alternator doesn’t have much excess capacity.
The stock points ignition has a dwell angle of about 180 degrees. (Points are closed for about 180 degrees.)
When switching to the stock alternator + electronic ignition, I would recommend not using a hall-effect ignition that has a really large dwell angle because of the extra alternator load.
Newtronics has a good system that’s popular for the triples. My GT750s have it.
Their website mentions that some adjustment for the T500 may be needed. I vaguely remember reading something about a spacer.
http://autocar-electrical.co.uk/product ... mc/ckt-su7
Accent has a good system that’s popular for the triples. My GT550 cafe build has it.
I bought their T500 unit but have not yet installed it.
They don’t have much of a website. Ask questions & place orders via email.
http://www.accent-electronic.com
Posted: Mon Oct 30, 2023 5:07 pm
Good suggestions there. Cheapest by far is a DYNA copy from ebay for any 4 cylinder 4 stroke. You will have to modify the backing plate to replace the points plate but they make a fat spark and are very cost effective.
Posted: Thu Nov 02, 2023 3:25 pm
by kall399
Thanks for the tips!
I think the best option for me would be the vape ignition system since my original stator appears to have developed internal shorts and isn't charging properly anymore
