8 petal Polaris reed intakes
To use some of the extra parts collected for the GSXR / GT750 build i picked up cheap off ebay a Polaris triple snowmobile case . I will cut these up as i did the Arctic Cat cases to get the reed boxes off .
- Country: USofA
After a few minutes on the band saw reduced the cases to boxes
- Country: USofA
- johnakay
- I likes them jubblies
- Suzuki 2-Strokes: bike
John , you are correct they do provide more power in a round about way . As you tweek 2 strokes for power the power band gets higher and more narrow . Manufactures and tuners try different methods to regain some of the shifted power band by useing water injection , variable exhaust ports , special designed chambers , other methods and what we are adding reed intakes . With the piston port engines these GTs use you can only raise the intakes so much and then the intake charge blows back out the intake and not up the transfers before the piston can close off the port , reeds help "fix" this problem as when they loose the intake draw signal they close off helping prevent this reverse flow. It is still a complex system that i have skimmed thru but this is the basic idea .
- johnakay
well that clears one matter up.
I know nothing about tuning or where to start.
the only bit of tuning that I know is polish all ports/heads and thats about it.
chears Dave.
chears Dave.
Nothing wrong with a good port polish and matching , just that alone could make a engine run a bit better as most if not all engines were not cleaned up very well in manufacturing the ports .johnakay wrote:well that clears one matter up.
chears Dave.
