Just finishing off my 380 build, wiring etc to do yet, bought half completed, so it is a GT380 72 reg plate which acording to the previous owner, and the receipt from the engine builder it is "race Tuned" what spec I have no idea.
it is running Amal 2600 MK2 concentric in two stroke spec cleaned by previous owner
anyway it is time to start the engine
Fuel in, pulled the choke out no start,
check its sparking OK on that side,
try again forgot to pull the choke fired right up and ran ok and rev'd cleanly.
pulled the choke just died.
Mixture too rich? adjusted the air bleed screw no effect.
removed carbs to look at the pilot jet sizes no markings but a 1 mm drill fits down snugly
sound too large for me but I dont know.
So my question is has anyone any experience with Amal carbs and jetting, they go by flow rate not mm size
approx what size would be a good start point? or do I just plump for a size and work backward or forwards from there
Martin
