Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Fri Jul 10, 2020 8:36 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Sat Aug 18, 2018 6:34 am
Offline
Country: australia
Suzuki 2-Strokes: t250
tank
Top
 Profile
PostPosted: Mon Dec 03, 2018 7:29 am
Offline
Suzuki 2-Strokes: T250, GS550, TL1000S, T500 race, GSXR400 race
Ben, did you ever get this to rev properly? If so what was the issue? I had a similar problem (not quite so pronounced) with mine in the early days and it ended up being pipe dimensions. I also found to my surprise as we retarded the ignition timing (Zeeltronics) it kept making more power.
Top
 Profile
PostPosted: Mon Feb 25, 2019 5:25 am
Offline
Country: australia
I did get the problem solved. After I replaced the fuel tap I took the bike out to local track at Broadford. Short 2 km track. First session bike cut out after 2 laps. Took bike back to pits & it started again. Took bike out again & it cut out again after 2 laps. Was revving to 8000 rpm though. Pulled R/H cylinder off & had partial seizure. Was advised when I bought bike to run oil pump at about half & 100:1 fuel mix. Problem was not enough oil. Replaced Piston honed bore & ran 25:1 fuel oil mix & no further problems. Bike has ran 3 race meetings without a problem.
Top
 Profile
PostPosted: Mon Feb 25, 2019 7:10 am
Offline
Hello Ben,
I holed a piston the first time I took my Seeley T500 on track. Suspected cause was fuel starvation due to the taps not flowing enough fuel at full throttle. I replaced them with taps designed to flow methanol, which of course provide a much higher flow than petrol taps. I run pre-mix only at 20:1 (Castrol A747)
glad you got yours sorted :up:
Cheers Geoff
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 29 guests
Jump to:
Suzuki2Strokes.com
