Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Wed Mar 20, 2019 2:30 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: ignition timing.
PostPosted: Tue Feb 20, 2018 4:29 pm
Offline
Country: Quebec canada
Bikes owned: T500,gt500, tc185, gs750es, gs550ef, rm250
Was wondering what people were running for ignition timings on modified t500 engines.
Tr500 spec porting and chambers, squish heads, borderline unacceptably high compression ratio...
Top
 Profile
 Post subject: Re: ignition timing.
PostPosted: Tue Feb 20, 2018 6:54 pm
Offline
Bikes owned: T500R, SV1000S, TS125, Seeley T500
Hi Jg,
What fuel are you using as it will impact upon timing. If it is premium unleaded I would start at 2.4mm BTDC and develop from there. If you are using a leaded race fuel your engine will tolerate more advance. I would still advise to start at a conservative BTDC figure and work from there, ideally on a dyno where you can see the affects of changing the ignition and jetting.
Cheers Geoff
Top
 Profile
PostPosted: Thu Feb 22, 2018 7:30 am
Offline
Hi Geoff
I was hoping to be able to use 94 aki pump fuel.
Apparently that is what the PO was running in it, but the squish clearance and compression ratios leave much to be desired. I suppose i will start on the conservative side of things.
Jordan
Top
 Profile
PostPosted: Thu Feb 22, 2018 8:02 am
Offline
Hi Jg,
Modern unleaded pump fuel burns faster than old style leaded petrol, hence the general need to run less advance than before. I would recommend that you get the best "premium" pump fuel. In the UK I use Shell Advance which is about 97RON, although I then mix it 50:50 with 100LL AvGas.
Squish - I would keep it to a minimum of 1.00mm, my race engines run about 1.2mm
C/R - My heads have been worked for a 24cc combustion chamber volume which is conservative but keeps detonation at bay.
Cheers Geoff
Top
 Profile
PostPosted: Sat Feb 24, 2018 7:13 am
Offline
Hi Geoff
The problem i have is that the squish is around 1.6mm at the moment, and the combustion chamber holds 18cc at this clearance.
While the previous owner claims they ran pump fuel, i’m a bit sceptical about that with a 15.1:1 compression ratio.
That being said, i’ll try to err on the side of caution when doing things.
Jordan
Top
 Profile
PostPosted: Sat Feb 24, 2018 5:56 pm
Offline
World Superbike
Bikes owned: GT550s GT750 GSX1400 and lots of spares
2 stroke compression is measured from closure of the exhaust port. Not bdc. Use a pressure gauge in the plug hole and see what psi you get. 'Normal' will be about 120-125psi. Skimmed head/barrels/different porting could be over 150, but that's getting high for longevity.
Top
 Profile
Who is online
Users browsing this forum: Evans Ward and 20 guests
Search for:
Jump to:
Suzuki2Strokes.com
