Sprocket question.....
I'm starting work on one of my T500s, and plan a bit of a tune up as well as a cosmetic change. I also plan to lower the gearing to get some extra response low down. This is my question....will rear sprockets from the other GTs fit onto the 500 hub? The 500 runs a 33 tooth rear as stock, and I know the 250, 380, 550 and 750 were all bigger, though I don't know by how much.....but will any of these interchange with the 500? I was hoping to jump up to 37 or 38 ish......
Jimroid
Re: Sprocket question.....
Post by Jimroid »
http://shop.pbisprockets.com/product.sc ... egoryId=45" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" And if you go with 520 chain DR200 http://shop.pbisprockets.com/product.sc ... egoryId=44" onclick="window.open(this.href);return false;" ;
Thanks for that Jim R.......so it would appear from that link that all of these models are the same mounting.. GT-380, GS-400, GS-425/450, GT-500, T-500, GS/GT-550. as you are not asked what model you have, but simply how many teeth you require.
Jimroid
Post by Jimroid »
Correct.
