Running Lean
Running Lean
My Bike is running lean. The spark plug is white not brown.
Any suggestions, carb was rebuilt
- My new bike is "IRIS"
Did you use everything in the Keyster carb kits? The jets normally do not work so well. If you did, try putting the originals back in, and remember the middle one is different in size from the outer two, due to the way the exhaust is set up. Also, check to make sure you are not getting air leaks around any of the connections between the airbox and the carb intakes, if you are sucking air in somewhere it could be an issue.
Kevin
Kevin
Everything Commeth
To He Who Waiteth
So Long As He Who Waiteth
To He Who Waiteth
Do all of the spark plugs look the same?
Yes if you adjust the jet needles higher by putting the clip into a lower groove you will richen up the midrange.
Here is a link for some instructions and adjustment procedures if you tear into the needles.
http://www.3cyl.com/~tripleed/suzigtcarb/
Try swapping the needles back for the stock ones in the stock clip position and see if that improves things
Some Keyster needels are way off spec and it's possible that yours are. Stock 550 needels are an unusual spec and are pretty lean, so if the keysters are even slightly larger, you would have a problem.
Helix,
I just noticed your other posting. The bike has not run in 13 years. So tell me how clean the petcock is and the fuel lines into the carbs and the needles and seats. Is the breather in the fuel tank clean, is the timing absolutely spot on?
I'm not questioning you ability, just trying to determine what was done and what might have been skipped or "underdone".
After 13 years of non use, lots of things change.
Fuel lines are new and clean.
The petcock is another matter, I am not sure how to clean it, is there a filter and where is it. Do I have to replace seal in order to clean it.
All the needles and seats are new.
What's the breather in the tank?
Timming is spot on and is converted to electronic Boyer Brandson.
I am definitly going to swap back the original needles.
Was hoping to not have to.
I'd drain the tank and then remove teh petcock. The filter is on top, inside the fuel tank. As you drain the tank you'll get a good idea how well the petcock flows and if the fuel starts to stop (so to speak) and then sort of gulps out, the small hole in the filler cap that lets in air as the fuel is used up is clogged.
Are your carbs on rack? IF so it takes a lot of time to strip and clean them or to adjust the needles. Once they are off it would be good to check the choke circuits to ensure they actually close off. Blow through every passageway and compare that to the other two carbs - circuit at a time. You would be surprised how different they can be.
With needles out, try to measure them at say 10mm up from the tip and compare the diameter to a stock needle at EXACTLY the same spot.
Make sure the vacuum hose is connected to teh petcock and there are no air leaks anywhere.
Helix. I personally have not had any success using Keyster carb kits. The manufacturing tolerances just don't seem to measure up to factory Mikuni. My wifes 380 ran dismally with Keyster kits installed, and returned to good running order when refitted with original jetting and needles. I don't know if thats a common thing, but I won't risk the money and effort to try them again. Good luck with it. Cheers.Helix wrote:Late 74 GT550
No Mods
Keyster carb kit
Not sure altitude by I am near Toronto
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
