'75 GT 550 Timing
Apexxn
Country: United States
Suzuki 2-Strokes: H1, RD, NSR, MT1
'75 GT 550 Timing
Post by Apexxn »
Are you guys still setting the timing at the service manual suggested 3.37(top of my head don't have the manual in front of me). I know on some of the other vintage strokers I don't go with as much timing as the manual states. For instance Yamaha RD manual 2.3 and now a days everyone sets it at 1.8.
GTandcbr
Country: WALES
Re: '75 GT 550 Timing
Post by GTandcbr »
Clymers says B.T.D.C 3.37 or 0.132 in and it also says to do the left pot first.
98 carb Blackbird and GT550j
I found my GT380 preferred the timing to be slightly retarded compared with the factory recommended 2.25mm BTDC. I used to run it at 1.9mm BTDC, and it ran happier there.
It always felt a bit 'on edge' to me, at 2.25mm. Dyno tests have shown that on a stock motor, having the timing retarded by a fraction makes no difference to power and torque anyway, and it's far less likely to hole a piston ...
Vintageman
Post by Vintageman »
If you retard the timing over stock you loose power with respect to how the bike was designed. The GT550 is not high revving even if you mod it a little. It has a very broad mid-range :up:
My Yams, I run stock timing :up:
I run chambers on all my bikes.
Try it both ways see what you think.
This is where I am
