Cylinder head temperature
A.Holley
Suzuki 2-Strokes: T500, 1200 Bandit, 125 Stinger, Triumph R3
Post by A.Holley »
Hi guys,
Have just fitted a cylinder head temp gauge ( Trail Tech) to my T500.
It's the type with a sensor under the spark plug in place of the washer.
Has anyone else fitted one, and what sort of temps should I be looking for under normal operation?
Any info greatly appreciated
Andrew
Re: Cylinder head temperature
Interesting article here from Cycle mag in the 70s, about testing oil premix ratios. It mentions plug washer temps, although it is in a Suzi PE enduro bike. Generally, the article mentions temps above 380 - 390 farenheit are getting into the danger zone.
http://www.bridgestonemotorcycle.com/do ... remix6.pdf" onclick="window.open(this.href);return false;
A.Holley
Post by A.Holley »
Thanks for that, gives me a base line to work from.
As the saying goes, knowledge is power.
Andrew
Vintageman
Post by Vintageman »
I played with these on rotax fan cooled and free air engines for sleds... useless buggers to paraphrase -> http://www.ultralightnews.com/enginemai ... gauge.html" onclick="window.open(this.href);return false;. Some of these engines were also used in ultralights and they care a bit what's going on... Best is to measure exhaust temp.
Current Bikes
Zunspec4
Post by Zunspec4 »
Hello Andrew,
I have a pair of TTO gauges which use the under the plug sensors. During dyno testing on my race engine the max temperature was 130 C . If you are running in the 90 - 110 C range I would say you are OK. It would be interesting to see what you actually record.
Cheers Geoff
ChrisK
Suzuki 2-Strokes: T250, GS550, TL1000S, T500 race, GSXR400 race
Post by ChrisK »
I've just had a bit of a blow up at the Island Classic as you can see!
This side was running at about 135 (the other around 100) which we think was caused by an air leak. We are using CHT and (shortly) EGT from The Sensor Connection using these gauges. http://thesensorconnection.com/egt-elec ... ge-display
I have to give them a shameless plug as they are a sponsor of our team :up: but their products are first class and if anyone is wanting to fit their bike with some sensor technology, I can highly recommend them - just act on the information they give you! :wink:
Leak down tests are a great idea :up:
ChrisK
Post by ChrisK »
Yep! Currently making some bits to be able to do just that.
A.Holley
Post by A.Holley »
Geez Chris, that had to hurt.
I have been very lucky, ( touch wood) and never holed a piston since I started with the T500 in 1975.
And that includes 15 years of racing in Post Classic class, including places like Mt Panorama .
I will admit I tend to be very cautious with jetting.
Maybe that's why I didn't win a lot of races!!!
Andrew
ChrisK
Post by ChrisK »
A.Holley wrote: I will admit I tend to be very cautious with jetting.
Andrew
:lol: maybe I'll start using that as one of my excuses!
A.Holley
Post by A.Holley »
The problem with jetting is, there is a very fine line between grenade and glory.
