T500 exhaust seals
Posted: Sun Oct 04, 2015 5:48 pm
by greens888
Hi, just got new exhaust seals supposed to be for standard mufflers but too big too fit as the old ones fitted. Will not go in to the locating space just inside the muffler. Made of rubber over metal by the looks with the wire spring inside. Absolutely cannot be compressed into the muffler even when heated up to boiling point of water. Must be wrong. Any tricks I haven`t figured out? Steve.
Re: T500 exhaust seals
Posted: Mon Oct 05, 2015 11:33 am
by titan performance
They are a very snug fit Green....
Boiling them will only make them bigger. Heat the muffler and put the seals in the fridge. I have always had to knock them home with lube and a rubber mallet.
Posted: Fri Oct 09, 2015 1:33 am
by greens888
I will try it but I just can`t see them fitting, can`t hurt to try, thanks.
