t500 '75 timing- set the points which side is which?
- PippiFyrecracker
- Suzuki 2-Strokes: 1975 T500, 1983 SP250
which point is which for the left and right cylinder?
- ConnerVT
- Novice racer
Re: t500 '75 timing- set the points which side is which?
The point which is opening when you see the "L" coming into the circular window is for the left cylinder.
- PippiFyrecracker
okay thanks, we weren't sure if the L and R marks were for TDC or the firing point, so we used a dial gauge, all good now! I just really hope I can remember how to do everything that I learnt today!
- ConnerVT
- Novice racer
The mark next to the letter is where the points should just open up - the same as where the dial gauge says the timing should be set.
