t500 '75 timing- set the points which side is which?
PippiFyrecracker
Suzuki 2-Strokes: 1975 T500, 1983 SP250
Post by PippiFyrecracker »
which point is which for the left and right cylinder?
ConnerVT
Re: t500 '75 timing- set the points which side is which?
Post by ConnerVT »
The point which is opening when you see the "L" coming into the circular window is for the left cylinder.
PippiFyrecracker
okay thanks, we weren't sure if the L and R marks were for TDC or the firing point, so we used a dial gauge, all good now! I just really hope I can remember how to do everything that I learnt today! :)
ConnerVT
Post by ConnerVT »
The mark next to the letter is where the points should just open up - the same as where the dial gauge says the timing should be set.
