Just wanted to share this with you, as many of you have either helped with concrete solutions, or suggestions. I got the T350 giant make over done tonight, so i was thinkig that i wanted to start it tomorrow... But then hey, why not try to kick the thing, 3rd kick and it started, chrisp and loun popping sound - WOW. I warmed it up, and took the chocke off and it instantly settled on 1200 rpm, and good throttle respond. Only smaal noticeable thing is some low noice from the barrels, but remember they are still on std bore, only thing i did was a LIGHT hone and new pistons and rings - all NOS. I have desided if the tune went well i would rebore it during the Winter. Then i went in the house as it was 1030 in the evening here, smiling all over. Sat Down in the sofa, and thought it all over a Little, the it came to me, why the heck didn't i try it? Last time i adjusted the ignition, last year before this tune, i remembered it as i left it a bit retarded compared to factory spec, so i couldn't be all wrong.
I took a desition, helmet on and went for a drive.
Well here is the verdict.
The midrange is a littlebit weaker that before, but pretty intact, so from 3 - 5000 revs very comfy, no issues. Even WOT at 3,5k is working. And after 35 km up and Down in speed i tried to give a Little more without over doing it, remember Again it is old barrels ofcourse with new pistons but i don't have to give it as many miles as new bore demands.
KABOOM from app 6k and up (i stopped at 8k but there was alot left) it really went off, and totally changed the charateristics and the exhaust note / sound. I have had many RD350 aircoolers but this T350 feels more powerfull now. Maybe it is, or maybe it is the bigger difference between midrange and the take off that makes me feel so.
I still have some fine tuning to do, but the jetting still seems great, and the ignition isn't bad at all, so more test riding to come
Just a short refreshment on the data:
Barrels have been shaved at bottom to clean surface.
Baseplate have been added.
Barrels have been shaved at top to get the deck height back.
Exhaust have widened.
Intake the same and lowered 2mm + baseplate.
Bottom of exhaust + transfers have been lowered so they fit the piston at BDC after the baseplate have been fitted.
Kawa H1heads habe beed cut with squish to fit T350. 50/50% area. 1,1mm gab, 140 psi.
Keihin PWK 28 carbs
Y-boot KN
RD400 modified DG chambers with modded stingers 160mm Id 22mm, and new HVC mufflers
DYNA Harley ignition.
KONI shocks rear.
Honda valve springs in front forks as preload, still playing with oil type.. (any suggestions?)
So Thanks Guys, TZ, Ja-moo, and Vintageman
