crank pins
- Country: United States
- Suzuki 2-Strokes: t20 ts250 t500
crank pins
Hi, rebuilding my t500 crankshaft and have a question about the oil hole in the crank pin, I'm using a different pin which doesn't have a hole and the only bit that I found that will drill it is a masonry bit and its about 3.4mm as compared to stock hole of 1.6mm. Do you think would be a problem. Thanks
