"Pork Chop" Cranks for GT/TR750
Kris Bernstein
Template
Post by Kris Bernstein »
Of course! Turn the ID of a steel tube to the OD of the piston and bore holes for a dummy pin to isolate the piston in the mill. I could use a ball end mill to duplicate the radius of the Suzuki piston cutaways. Way too simple and no program to write!!!!
Kris
Kris Bernstein
Reeds and intake opening location
I think Dave is right about getting the reeds as close as possible to the bore of the cylinder. It is going to be a compromise with this old motor but I am going to try to do this without "hitting water" as it were. I might not be able to do it but we'll see...
Kris
Kris , i dont know if you are sitting in on this topic but its getting pretty interesting http://www.motorcycleracer.net/phpBB2/v ... php?t=1506
Kris Bernstein
Osolot Piston Jig?
TZ375,
Did you ever recover the picture of the Osolot piston jig?
Kris
Kris,
My new monitor for the desktop just arrived as did teh memory and hard drive for my laptop, so i should be able to gig those pictures out real soon.
try this
and
Kris Bernstein
Osolot Piston Jig?
Simple, yet elegant. Usually the best resolution to any engineering issue.
Thanks so much for sharing.
Do you know if the 75mm pistons require re-sleeving or is there enough meat in the original iron liner to do these?
Kris
If i were to start with a "blank" piston like those wouldnt the new thinking with piston tops be flat , i know that would aslo require a new "topHat " squish head design also ?? Image
Or maybe toroid Image
Kris Bernstein
Yamaha Head
What's the head to Dave and what evil plans have you for it?
Kris
Kris , the picture i picked up off Ebay as a good example of the state of the art toroid head design . I think it was from a 1300cc PWC engine , i think i have dug myself a big enough hole that i have to get out of with my engine now and getting it together and running in its current state of mods is my goal :D
Kris, when you start playing with head shapes, don't forget that unleaded seems to work better with a flat top and leaded with a tapered chamber. Toroidal shapes are designed to put the plug close to the center so it burns faster.
Unfortunately it also increases the ratio of surface area:volume which results in more heat being transferred to the water instead of being used to generate useful work. The faster burn should help with slow burning ethanol mixes but the burn rate improvement is probably less than the heat loss effect on a race bike.
Just another compromise to deal with.
And we really need someone here to be trying this stuff out and sharing the knowledge. It's all about creating a wider, deeper pool of knowledge to draw from.
Richard , the only guy i know that could possibly do different head shapes and try the on a dyno would be Bill . If he only had a 1 cylinder GT750 engine he could run tests on his dyno .
Dave,
I think that Brett has a single cylinder GT750 set up for his dyno.
I have to get the single cylinder GT crank pressed up. I have the right ignition system etc and spare cases, and don't need water pump or tacho etc for the dyno (I can use an electric pulse pump and electronic tacho or teh dyno tacho).
I can't remember what the capacity of Bill's engine dyno is, but I though it was limited to about 125cc or less.
He could of course try different heads and a range of fuels on one of his small motors, but I don't know how well that would translate to our big bore high primary CR motors.
I don't have a dyno so I need to talk to the sled guys in Kenosha about making up an engine cradle to fit their dyno to test some ideas.
All it takes is those two simple ingredients - Time and Money.
