Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Mon Sep 24, 2018 10:26 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: 32mm jetting.
PostPosted: Tue Nov 07, 2017 4:07 pm
Offline
Bikes owned: TS100, T200, GT250, T500, GT500, GT550, GT750, GS750
If you have an early T500, (1970), with 32mm carbs, is there any reason why you can't remove the round 150 main jet, and replace it with the later 97.5?
_________________
Top
 Profile WWW
 Post subject: Re: 32mm jetting.
PostPosted: Tue Nov 07, 2017 11:04 pm
Offline
Isn't the first generation of 32mm carbs "homopressure". If so, they are jetted quite differently because of the different float bowl pressure compared to regular VM type carbs and it's pressure differential between the venturi and float bowl that pushes fuel onward and upward.
Top
 Profile
PostPosted: Wed Nov 08, 2017 12:22 pm
Offline
Thanks for the response TZ...
I have zero experience with these early model 32s. Are jets available in increments of 2.5 like the later ones?, and what are people changing up to when running chambers and pods?
_________________
Top
 Profile WWW
PostPosted: Wed Nov 08, 2017 4:14 pm
Offline
Bikes owned: T500R (now), T500M (30 yrs ago)
'72 and older have the homo-pressure carbs, with the bowl vented at the mouth of the intake. '73 and newer have standard carbs, with the bowl vented to atmosphere.
The older carbs need the larger 150 Main Jet. Even when mated to a '73 or later engine.
The large round Main Jets are available in 2.5 increments.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 16 guests
Search for:
Jump to:
Suzuki2Strokes.com
