Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Apr 19, 2018 3:03 pm
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Making tapered headpipes
PostPosted: Fri Feb 24, 2017 11:46 am
Offline
Bikes owned: GT500 T500 GT750
Parallel headpipes do not make max power and cone sections are tedious. I cut a narrow sliver out, and starting at the small end of slit, gradually pinched it together with 3 hose clamps. I welded [tig] in short 1/2" to 3/4' increments gradually drawing together and welding. It works better with short movements. I used 16 gauge,but 18 gauge would of course be easier.I used a nut driver for speed and a 1/4" ratchet for torque.Use all three clamps in an even and back and forth pattern.Don't get too aggressive,you will strip the hose clamps and start a ripple in the headpipe.My second pipe turned out better than the first as I learned quite a bit from the first one.
Top
 Profile
PostPosted: Fri Feb 24, 2017 12:16 pm
Offline
Bikes owned: '72 gt750
This is a great idea, thanks for sharing!
I assume you had a known diameter of pipe at the head that you were targeting and used the circumference to figure out how wide the cut out vee should be at that end of the pipe? Then drew a straight line down to the point where the 2 sides of the vee converge? I'm just trying to figure out the process here..
_________________
'72 GT750
Top
 Profile
PostPosted: Fri Feb 24, 2017 12:37 pm
Offline
Exactly. I used a paper template from my dimensions,taped the template in place,marked with a black marker, and cut with a jigsaw. It was very easy to cut.
Top
 Profile
PostPosted: Sat Feb 25, 2017 6:59 am
Offline
Bikes owned: T250, GS550, TL1000S, T500 racer
Nice work Jim!
Top
 Profile
PostPosted: Mon Feb 27, 2017 7:45 pm
Offline
Bikes owned: GT750
Good idea. How much did the radius increase?
_________________
'79 KZ650SR w/162hp Polaris XC700 Snowmobile Engine Dragbike
'73 GT750
'74 H2 750
'90 GSXR 1100
'75 H1 500
'76 KH400
'76 RD400
Minitrail 50
2 Trizingers
Top
 Profile
PostPosted: Mon Feb 27, 2017 8:44 pm
Offline
That is a great question. The 6" radius stayed a 6" radius.
Top
 Profile
PostPosted: Wed Mar 01, 2017 6:50 pm
Offline
Country: United States
Bikes owned: T500
Nice work Jim :up: I am definitely going to try this on my next set of pipes, not sure I can make as good of a job as you did but it's worth a try :D Was this your own idea Jim? Hard to believe I haven't seen this before seeing how much research I've done with regard to build expansions!
Top
 Profile
PostPosted: Wed Mar 01, 2017 7:06 pm
Offline
Yes,I came up with this one on my own. I thought it through a few times and just couldn't see a reason not to try it.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 14 guests
Search for:
Jump to:
Suzuki2Strokes.com
