They were supposed to be timing numbers - at least that's what the guy that drew it said he had calculated.sfront wrote:I took the degrees pictured to be radial dimensions of the ports and not timing numbers.
A diagram like this for a 750B would be great.....anyone have one!
Even an untidy version would be fine!
Exhaust on an MAB is quoted at 40.0mm below TDC compared to 42.5 on J/k/l motors. Timing is very conservative on the GT series and pipes on their own make a small difference, but work much better with revised porting. The easiest way to 80HP is a spacer plate, mild port clean up and a set of JEMCO pipes.
The only way top know exactly what your motor's port dimensions are is to pull the top end.
