Archived Posts
- Supreme UFOB
That looks like an easy one.
Ralph,
That looks like an easy one. I think JB Weld will cover that hole in the piston, and that con rod is definitely within factory spec for straighness, so I wouldn't worry about it. You'll be back running in no time.
Kevin
P.S. Anyone who thinks I am even remotely serious needs their head examined. Ralph knows I'm joking, and I'm (and I think he is too) pretty stoked that he got so many years out of racing that engine before having to do a major rebuild.
Kevin
- Supreme UFOB
Final gory pics of carnage after engine disassembly.
The piston pin was ripped out of piston pin bosses, and somewhere the con rod small end was severed from the rod.
The resulting reciprocating saw toasted my cylinder wall with deep gouges.
Note the scuffing from seizure, and nice groove cut in piston skirt from flailing con rod stub.
I don't doubt that the piston seized, but I don't really think it was from lean mixture as the right cylinder looked fine.
Interestingly enough when I dissassembled the top end the left "seized" cylinder was completely devoid of any two-stroke oil residue, compared to normal residue present in right cylinder. Think I better check out the oil pump, lines and check valve.
So now the rebuild process begins; I've got a spare crank sent out for rebuild, and I'll send the left cylinder out for re-sleeving.
That's racing!!!
That's racing!!!
- Supreme UFOB
It is but a flesh wound!
"It is but a flesh wound!"
"But you have a hole in your piston, a broken and bent connecting rod, and horrible gashes in your cylinder walls!"
"Alright, we'll call it a draw!"
Sorry for the bad Monty Python paraphrase.
- Supreme UFOB
Racing Tires?
Can anyone recommend a good place to pick up a set of Dunlop racing tires?
