Archived Posts
- Supreme UFOB
- Supreme UFOB
Don't forget, what ever racing organization you choose to race, you need to adhere to their rules. If you plan on racing in several than you must read all the rules for each and then build your bike accordingly.
I posted a link in this Subject to the AHRMA rules. You need to abide by them to race in AHRMA at Mid-Ohio and other AHRMA races.
- Supreme UFOB
I just read the AHRMA rules and this concerned me:Zook-e wrote:Don't forget, what ever racing organization you choose to race, you need to adhere to their rules. If you plan on racing in several than you must read all the rules for each and then build your bike accordingly.
"New, novice AHRMA roadracers may not be permitted to ride at certain venues"
Does this apply to Mid-Ohio. I asked a cb350 racer friend of mine and he thinks it does, but isn't 100% sure.
- Supreme UFOB
I think the only difference between what jim posted and what JMC does is that JMC's brace is further than 2 inches from the arm and made of box tubing instead of 5/8" round tubing.Adam wrote:So it looks like according to the rules, the ONLY form of swingarm bracing is the style Jim posted. I guess I'll do that then!
Does anyone have any info on bracing the T500 frame?
- Supreme UFOB
Geeto67 wrote:I just read the AHRMA rules and this concerned me:Zook-e wrote:Don't forget, what ever racing organization you choose to race, you need to adhere to their rules. If you plan on racing in several than you must read all the rules for each and then build your bike accordingly.
I will read it again but at the riders meeting this year I believe that you have to have two races in before Mid-Ohio to qualify. The two prior could be at BeaveRun in PA north of Pittsburg.
Eric
- Supreme UFOB
T500 road racer - preferred rim/tire size?
All,
I know AHRMA specifies rim sizes for Formula 500 to be no less than 18 inches in diameter and no wider than 2.15 inches (WM3) up front and no wider than 3 inches (WM5) at the rear.
I was wondering what the T500 racers here prefer in terms of rim width and tire size? Also, what brands work well?
Jim
Jim
- Supreme UFOB
- Supreme UFOB
Re: T500 road racer - preferred rim/tire size?
Mine will be running 2.15 up front and 2.50 rear and will be shod with DunlopsDiamondj wrote:All,
Jim
- Supreme UFOB
- Supreme UFOB
Zook-e,Zook-e wrote: Mine will be running 2.15 up front and 2.50 rear and will be shod with Dunlops
Thanks! I guess you found a 2.50 rim? I'm asking about rim sizes as I have a decent 2.75 rim for the rear and a new 2.15 for the front that I would like to use. I'm thinking a 100 width tire up front and a 120 in back would work well. Do you think the 120 profile will be too "flat" on a 2.75 rim versus a 2.50? I guess I could go to a 130 if they are available and it won't "overtire" a T500. Were there more 2.50 rims where you dug up your 2.50?
Jim
- Supreme UFOB
Here is the link to the Dunlop tire site for racing Dunlops. 2.75 should be okay but look at it to be sure.
http://www.rcbtires.com/
I will be running the KR124A front and rear on mine. Ralph Spencer was running the KR825 front and KR124A rear on his and he had 2.15 ront and 2.50 rear rims.
I didn't like the rear low profile on his front tire.
