Hey Kris,Krash wrote:I don't understand why you need a cush drive? I run a yamaha dirt bike wheel on my racebike. The sprocket bolts directly to the wheel. The wheel is 11 pounds lighter than the stock suzuki 500 wheel with the cush drive, and it eliminates that sloppy cush drive feel.
Maybe it's a lack of understanding on my part of the cush drive's purpose. As I understand it the cush drive is there to cushion the shock to the driveline and reduce wear on the chain, sprockets, tranny output shaft splines, etc... Plus a modern enduro cush drive is a lot smaller and lighter than the ones originally used on the T500. I take it you have not noticed any appreciable wear and tear on your driveline? How has your CR trans held up?
It could be I'm overthinking this as usual but I'm trying to strike a balance between strength, durability, and lightness.
I want the extra disc to maximize my ability to be an orange vested rolling roadblock on your racing line.Krash wrote:I also don't see the need for a disc rear brake. The rear brake is very seldom used on the track. I use it occasionally to settle the bike coming into a corner, but as far as slowing the bike down, it's all done with the front brake. There are many successful road racers out there who have made a career without ever setting foot on the rear brake. I know racers who purposely use spongy old lines or do a poor bleed job so that there is less chance of the brake locking up. I also think a drum set-up might be lighter than a disc, unless you get some really trick dirtbike stuff.
Thanks for the insight Krash - keep it coming!!!
Jim
