Anyone know how the hi low switch works, can this be shifted while moving in any gear or like a car, must be stopped.
Have a shop manual. Cant find an owners manual.
Ben
RV125 4hi 4low
- Ben
- Suzuki 2-Strokes: 1 too few
RV125 4hi 4low
Ben in Canada
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
- H2RICK
- Country: CANADA
Re: RV125 4hi 4low
You MUST/MUST stop the bike itself (the engine can still be left running) to rotate the range lever/tee handle.
Once you are stopped, then shift the main transmission into Neutral.
Then twist the range handle.
You MAY have to rock the bike back and forth a very little bit to get the handle to engage properly.
You'll be able to feel the detent ball clunk into position when the handle is properly turned to the selected range.......assuming some yob hasn't left the detent ball and/or spring out at some time in the past.
Whatever you do, do NOT/NOT/NOT attempt to change ranges with the bike in motion !!!! You'll wind up with a very expensive collection of gear pieces if you do.
GT550A Mint & Original
MBD Sufferer
MBD Sufferer
- Ben
Re: RV125 4hi 4low
Much appreciated H2RICK.
Ben
Ben
Ben in Canada
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
