First,I want to thanks Lane for the efforts he made supplying me with a FREE genuine carb and buying for me various jets, needle, etc. for my TS400B, 1977.
When finally I got the Mikuni needle jets in P-0 and P-2 size, cause the original P-1 is NLA and a Suzuki particular item size, I realized what is wrong.....the mythological Previous Owner BORED THE NEEDLE JET, keeping the altough in very good condition, original jet needle; go figure how the poor engine would responds to this butchery.
After some trials and tribulations,I found out that the better combination seems to be: P-2 needle jet and 5F22 (3^ notch) genuine jet needle, #27,5 pilot jet and #185 main jet (large hex, again, thanks to Lane who addressed me to the difference between hex and round jets), float at 27 mm, needle valve #3,0.
NGKB6ES plug is currently light tan, almost no exhaust smoke, instant starting, no big problem at all; what is still there is the "surging" and little backfires when the throttle is closed after sustained steady speed, I noticed that the defect almost disappears setting the idle screw literally to "zero" and fiddling the air screw to obtain 800-1000 rpm idle; as you can imagine this is possible only when engine is hot and still it isnt' reliable enough.
Frappy and Buffalo, thanks for any informations you can give me and....yes, engine was entirely redone because the PO beast almost put an hole in the piston which is also chewed at the crown circumference, the oil pump was disabled, etc.; so new bearings and seals, cylinder bored 1mm. OS and suitable (heaviest) Wiseco piston and rings (wich seems to be far narrower than original ones), wristpin and caged bearing, cleared and chamfered ports, also the squared transfer divisory entry at cylinder base was worked and matched.
Last question: the piston is VERY noisy, especially you can hear it at idle and, more worrying, after the 5K rpm, where I prudentially cut the gas...at least 'till the counter will hit 1000 km.... piston/cylinder wall play set as per Wiseco/Suzuki instructions: 0,08 mm.; anyway, under the bench I have a complete second top end that includes a genuine Suzuki piston 0,5mm OS.....you know, just in case
(dont' tell to my wife... and I will post pictures of the bike in a kind of local miniature "Grand Canyon")
