Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Wed Jan 16, 2019 1:03 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: 1975 TS125
PostPosted: Thu Jul 14, 2016 6:49 am
Offline
Does any member have a picture of the stator for this TS125. I need to know color and number of wires. I'm thinking the stator on this bike may not be the correct part?? Pictures and Parts List seem to indicate either two or three coils on stator for this bike, depending on where you look. Thanks
_________________
1970 Suzuki T500 Titan Twin
1971 Yamaha HS1B 90cc Twin
Top
 Profile
 Post subject: Re: 1975 TS125
PostPosted: Thu Jul 14, 2016 6:41 pm
Offline
I did some checking and there appears to be a two coil or three coil magneto setup. The difference is the three coil units have a primary and secondary lighting coil while the two coil types have only one lighting coil. So the wires you should be seeing are as follows.
The dark blue wire is for the neutral switch
The black or black/yellow stripe wire comes from the primary ignition coil and points, then goes to the ignition switch and then on to the ignition coil for the spark plug.
The yellow wire is from the lighting coil (if you only have one) and becomes a yellow/white stripe wire goes to the ignition switch.
On a secondary lighting coil magneto that wire will be yellow with a red stripe. See if your ignition switch and harness carries such a colour.
There is also a green/white wire from the lighting coil that goes to the ignition switch which is inner connected through it to a white/red stripe wire which goes onto one side of the rectifier.
Let me know what you are seeing.
_________________
Top
 Profile WWW
Who is online
Users browsing this forum: No registered users and 5 guests
Search for:
Jump to:
Suzuki2Strokes.com
