Regulator Issue?
Posted: Mon Jul 08, 2013 5:55 am
by lpower
I have a 77 GT380, it has been acting funny lately. It starts fine, and runs fine until i stopped for gas, then it would not start. The lights no longer worked, and the plugs had no spark. i waited for about an hour or so, then it started. any idea what this could be? i read somewhere if the voltage regulator was bad, the ignition coils could get too hot.
Re: Regulator Issue?
Posted: Mon Jul 08, 2013 6:10 am
by GT750Battleship
:( How old is the battery,bad intermittent earth,dodgy connections..obviously electrical,if you have no lights as well as no spark ? Is the ignition key hot too the touch,just a hunch,had this problem on my 750A once ! Time to check with a volt meter ?
Battleship.
Posted: Mon Jul 08, 2013 6:54 am
by lpower
I never noticed the ignition key being hot, but i am going to check the battery and regulator today. i will also clean up all the earth connections. Hopefully i will be able to diagnose the problem today.
Posted: Wed Jul 10, 2013 5:32 am
by lpower
Turns out there was a loose connection in the battery connector clip. Should have been the first place i checked.
Posted: Sat Jul 13, 2013 11:40 am
by sportston
Don't worry, it happens more often than you think!
