Digital Gear Indicator Replacement Very Inexpensive
Re: Digital Gear Indicator Replacement Very Inexpensive
Looks like our admins are on leave ? :?
I just grabbed one off ebay for 5.99 with free shipping. Thanks for pointing that one out.
Ebayru
Suzuki 2-Strokes: 74 GT550, 90 RZ350 (Canadian), 78 DT250
Post by Ebayru »
tz375,
Let me know how it works out for you.
Did you see that I found out you don't need a voltage regulator? It works fine as it comes.
Another thing I would do differently is mount the gauge farther away from the exterior lens. I took great pains to get it as high as I could but suspect it might be better in bright sunlight if it were further down, like the original is. That way the sun wouldn't reflect off the face of the display which makes the unlit segments show and thus the gauge a little less readable in the direct sun. It isn't a big enough problem to change it on my bike, however.
Got mine today. Only 6 days shipping (including a Sunday) from China! How did you go about mounting this thing? There are no ledges, just a smooth rectangular box.
Ebayru
Post by Ebayru »
Coyote,
Sorry for the delayed reply, but I was on a cruise and didn't have Internet for a while. I see that you posted the day I left and I got home at 1:30 am today.
I made a bracket out of sheet metal with holes at the mount holes for the old gauge. It takes some cutting bending and drilling. I'm sorry I didn't take pictures during the fabrication, but it was a devise-as-I-went type project so I didn't know if it would be worth documenting when I did it. I drew an outline of the cross section of the gauge on the sheet metal which, as you know, made a rectangle. I then drew an "X" connecting the 4 corners and then cut the metal along the lines making 4 triangles with their bases being the outline of the rectangle. I then bent the triangles about 80% to make something like a spring washer/nut that are used for holding some of the emblems like the ones on the side covers. You can then push the gauge through the rectangle and the sheet metal triangles will grab the side of the gauge.
You'll have to play with it a bit until you are satisfied with the position of the gauge. As I said in a previous post, I wouldn't put it all the way up to the outside lens as I did; I'd keep it down a bit so direct sunlight won't interfere with readability. If you purchased the same one I did, you may have to trim the side of the gauge at the bottom where it hits the vertical section where the other indicator lights are located. Some of the other ones I saw on Ebay were shorter in height and those probably wouldn't need trimming. When I was happy with the positioning I used hot melt glue to lock everything in and on the bottom where the wires emerge from the unit because the wires used on the gauge are pretty fragile at the solder joints inside. I learned that the hard way and had to re-solder two of the wires. They come with some kind of hot melt-like glue at the bottom but it wasn't enough with all the manipulating I was doing while trying to figure out how I was going to install it.
I hope this is understandable. If not, ask me for further clarification.
Shel
SW550
Suzuki 2-Strokes: Past-72/75GT550,73GT750,77,78GS750/79 GS850.
Post by SW550 »
Thanks Ebayru,
Just ordered mine for $6.49 w/free shipping. :up:
1974 GT550
Ebayru
Post by Ebayru »
Good luck with it. FYI, it's been 3 years since I installed mine and it's still working perfectly.
Its possible to reuse the oem bracket/mount the old digital display was in, doing so makes life easy.
I want one of these. Nice post. Can someone share a link to the Ebay listing ?
Here you go, this one also has a green "N" if you care to use that feature.
http://www.ebay.com/itm/320907030237?ss ... 1423.l2649" onclick="window.open(this.href);return false;
Suzsmokeyallan wrote:Here you go, this one also has a green "N" if you care to use that feature.
http://www.ebay.com/itm/320907030237?ss ... 1423.l2649" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
:up:
Ebayru
Post by Ebayru »
When I did my installation, I was afraid to hook up the neutral wire to the display because I was worried that the upper range of the generated regulated voltage might blow elements of the display. I have a voltmeter on my GT and right after starting the voltage is at the upper end of the range and some LEDs will blow from over voltage. My fear may be unfounded for these units, but I decided to take the cautious route since I really dislike "do overs".
pull the wire
Country: united states
Suzuki 2-Strokes: 73GT750 75GT750 84RZ350 89 FXRS-CONV
Post by pull the wire »
Mine came in the mail last week. Mine still works but at least I have a great back up
Thanks for the great advice!
H2RICK
Country: CANADA
Post by H2RICK »
Pull the wire......Do you go out to the old bike nights up at the Pavilions in Scottsdale on Saturday evenings ?? I ask because we are now spending our winters in Mesa and I'll be bringing my 550 along with me this winter and would like to meet more old bike guys in the metro Phoenix area.
GT550A Mint & Original
MBD Sufferer
philshort
Suzuki 2-Strokes: GT125EC GT250B GT750 S&L GSX750F GSXR750F
Post by philshort »
I just replicated this, not realising it had already been done.
I got a digital indicator with the N. Rather than use brackets I used a hot air gun to melt the original indicator unit off its mounting. I used a heath robinson affair with 3 small cable ties to hold the indicator into roughly the right position, then fine tuned it by putting the cover back over and checking the position. Once happy with it I smeared black silicone sealant into the gaps between the indicator unit (which is not much more than 1cm square) and the old metal mounting, and made a black silicone cone shape very simiar to the rubber porthole thingy that sat over the original. Once set the silicone holds the indicator firmly in position, and has waterproofed the connections at the same time.
I actually found this thread because I was searching for an answer to my next problem - which colour wire corresponds to which gear?
Incidentally, if you wanted to use the N you would need to run a wire from the Neutral bulb, but if you have a B don't bother - on the indicator unit I have the digits are lit in red but the N comes up in green, and on the B model the mauve colour plastic window renders the green N all but completely invisible.
