Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat Jul 04, 2020 8:44 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: Wiring diagrams
PostPosted: Wed Jun 24, 2015 6:21 pm
Offline
Thanks for your advice mate, although it's not really the answer I was hoping for! -Would have been nice to have found a complete accurate wiring diagram.
I can see that the 'GT500 wire_updated' is right, but the differences in the other colour diagram add up to quite a lot of detail variations which can be pretty confusing.
(Especially with an old bike that may have been altered in detail by previous owners... if I knew 100% that it was factory original wiring I could more or less draw my own wiring diagram).
Not a perfect World eh?
Top
 Profile WWW
PostPosted: Tue Sep 29, 2015 12:31 am
Offline
Grrrrr!... Is it possible that Suzuki released 2 models (GT500A & GT500B) without releasing a complete wiring diagram for them?!!!
Hard to believe, but I suppose it must be the case. 'kin incompetent I reckon. -I suppose they were just running out parts, emptying the partsbins and shelves, but it's a shame. -Honda would NEVER have done that (it hurts me to say it but it's true).
Try as I may I'm still unable to find a COMPLETE, correct wiring diagram for my '77 GT500B. Yes, there's no end of diags for T500's, plenty of diagrams for the GT500 IGNITION SYSTEM (only), but none that I can find that is a COMPLETE wiring diagram for the GT500. So you'd think, well, just use the T500 diagram and snick in the GT PEI ignition system where it matters, but, nup, it doesn't work.
various details are different and won't integrate, wire colours are different, it's a mess.
As I said, Grrrrr!!!
(Please don't point me to some useless link where some well-meaning tosser labels a wiring diagram: GT500, when it's just the PEI ignition section, or worse, a useless T500 diagram).
-Jools
(You can tell I'm pissed off can't you! I'm trying to track down an ignition malfunction, No spark at all, but unless you're an electrical expert it's hard to check it thoroughly without a complete, correct wiring diagram).
I have got (tested on another bike) a good CDI, good Ignition coil, my stator ignition coils show 'ballpark' ohms (though one charge coil is stuffed, but that shouldn't affect starting and spark). Crazy thing is that the bike, after an extensive restoration, ran fine a few weeks ago, but then later, it refused to go with no sparks. Could this be the neutral switch? or Ignition switch? -what else? I've checked wiring and snugged-up all connectors.
Top
 Profile WWW
PostPosted: Tue Sep 29, 2015 8:09 am
Offline
Country: Germany
Suzuki 2-Strokes: GT250/380
Hi!
Have you tried X7 wiring diagramm?
This should be substantially equal.
bye
Markus
_________________
http://suzuki-gt250.de
Top
 Profile WWW
PostPosted: Wed Sep 30, 2015 1:16 am
Offline
Thanks Markus, good tip, (though I could only find a low-res image), BUT!!!
I may have hit the jackpot, and it was staring me right in the face! My good mate Jacko up the road who also runs a GT500B just happens to have an original owner's manual, and in it is the actual wiring diagram.
(He might have mentioned it earlier eh?) So I've scanned and optimised it.
Hopefully the attached file will work, -it's enlarged from the original, manipulated, and optimised, so it's as good as we'll get from the small original.
I have retained a high DPI setting to retain fine detail at A4 size, but some applications may require printing 'fit to page'.
If for some reason it won't work for you, PM me and I'll send the file directly to you via email.
-Jools
I don't seem to be having any luck attaching the file (it's only about 350k) so I'll add it as an image. Bugger!!! Imageshack, my image host is currently down, so that's stuffed too.
I'll try later. Maybe a moderator might help with attaching the file? When I try to attach the file I'm getting a silly message which tells me that the image size must be at least 0 pixels x 0 pixels, -it's 3071 x 1801 !
Top
 Profile WWW
PostPosted: Wed Sep 30, 2015 7:23 am
Offline
Country: Germany
Hi!
The GT500 owners here in Germany have the same problem with "no wiring diagram".
If you send the pic of the wiring (or the complete Manual-PDF) to my EMail, I'll put it on the "miscellaneous-Page" of my GT250-Site and post the link here and otherwise, for public download.
EMail = "info(at)suzuki-gt250.de" (change (at) against @)
Markus
_________________
Top
 Profile WWW
PostPosted: Wed Sep 30, 2015 6:21 pm
Offline
I've sent that Markus, so it should be available to everyone soon.
Jools
Top
 Profile WWW
PostPosted: Thu Oct 01, 2015 4:24 am
Offline
Country: Germany
OK, here we go... :mrgreen:
I put the GT500-wiring on my new download-site with some first links:
http://suzuki-gt250.de/index.php?b=6
_________________
Top
 Profile WWW
PostPosted: Fri Oct 02, 2015 1:50 am
Offline
Goodonya Markus.
Imageshack is now (finally) up and running so I'll attempt to show the wiring diagram file in this post, we'll see what happens!
-jools
(Sorry that the image is dimensionally large, but I wanted to retain good size/resolution for printing out full size on an A4 sheet).
Top
 Profile WWW
Who is online
Users browsing this forum: No registered users and 20 guests
Jump to:
Suzuki2Strokes.com
