gt 550 75 startermotor dead
carlo
Country: denmark
Suzuki 2-Strokes: gt550 m
Post by carlo »
When i push starterswitch nothing happens. It's completly dead. But there is power to the switch.
I got the problem for years now, and I want to fix it.
When I could use it, it was only functionel when engine was hot, not as cold. What,s the cause here?
Thanks for answer.
GTandcbr
Country: WALES
Re: gt 550 75 startermotor dead
Post by GTandcbr »
Hi Carlo. Just want to check. The starter motor does nothing at all? Not even spin over? I would start with the solenoid under the left cover. They can get very dirty and so power cannot get to the starter. You can check by connecting one lead of a multimeter to earth/ground and the other to the starter motor feed cable from the solenoid. Ignition on and press start button. You should get 12v. If not remove solenoid and clean terminals. I have attached photos to help
98 carb Blackbird and GT550j
+1 on the solenoid. It’s a common starter problem in older cars.
carlo
Country: denmark
Post by carlo »
Hi GTandcbr.
Few days ago I pushed the switch, there was only a sound like a short "click". Everytime I pushed. In the last time there is nothing atall. I have a multimeter but never used it. I'l try to figure out this.
Thanks for answer and photos
