Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Tue Jun 25, 2019 10:55 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Coil wire R&R
PostPosted: Sat Feb 23, 2019 4:16 pm
Offline
Country: United States
Bikes owned: 72 ts 185 765 gt750
Greetings,
I pulled the old coil wires out of a 76 750, but i am having trouble finding suitable replacement wires. I am looking for red 7mil cooper with a 90 degree red cap since I read here that the silicone ones are trash. My real issue is that I can't find a 7mil wire for the cap with a reduced diameter for the coil. Some of the silicone wires have the reduced diameter for the coil from what I can see on some of the photos. I can purchase bulk 7mil cooper wire in the desires length, but not sure how to reduce the other end to fit in the coil.
Any suggestions would be appreciated.
Top
 Profile
 Post subject: Re: Coil wire R&R
PostPosted: Sun Feb 24, 2019 7:38 am
Offline
Country: us
Bikes owned: GT
Did you remove the old epoxy that held the old wire in ? I replaced wires on 2 coil packs with 7mm wire, it fit nicely in coils and NGK non resistor caps, I bought 5 ft wire and cut to length. Make sure to epoxy new wires in coil to keep them secure.
_________________
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
Top
 Profile
PostPosted: Sun Feb 24, 2019 11:20 pm
Offline
I just measured a couple of coils that I removed the HT leads from and they are around 7.5mm, so as long as the 7mm leads are not oversized, you should be good to go once you dig out the old epoxy.
Top
 Profile
PostPosted: Mon Feb 25, 2019 6:59 pm
Offline
There was some of the coil wire sheathing left in the coil when I pulled out the wire. I took a 6.8mm drill and removed it. Problem solved.
Top
 Profile
PostPosted: Sun Mar 03, 2019 3:25 am
Offline
Country: England, UK
How is it possible to fit the new coils leads? Do they simply screw in? Or are they soldered?
Top
 Profile
PostPosted: Sun Mar 03, 2019 6:31 am
Offline
Country: us
Bikes owned: GT
Suzuki had two types of coils, grey and cream colored, my understanding is that the grey ones can't be repaired, but the cream colored ones can. The coil has a spike in the hole the wire pushes on, the wire is epoxied in place, the trick is to remove the wire and epoxy without damaging the spike.
_________________
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
Top
 Profile
PostPosted: Sat Mar 30, 2019 12:57 pm
Offline
Ah that is very interesting and useful. Thank you. I have a set of the old cream ones so I might be able to replace the leads. I didn't realise that. I'd put a cheap set of new modern ones but was not impressed with the quality of their leads at all (very thin core and not very flexible rubber)
Top
 Profile
PostPosted: Sat Mar 30, 2019 2:38 pm
Offline
Country: WALES
Bikes owned: suzuki gt 550j
Look here for help
https://www.google.com/url?sa=t&source= ... sLooCjNqXz
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Sat Mar 30, 2019 4:25 pm
Offline
That is a very useful topic. Thank you very much
Top
 Profile
Who is online
Users browsing this forum: No registered users and 6 guests
Search for:
Jump to:
Suzuki2Strokes.com
