Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Mon Feb 17, 2020 3:31 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Ignition coils
PostPosted: Sat Sep 08, 2018 6:18 am
Offline
Suzuki 2-Strokes: Suzuki GT380 B- Yamaha FZ1
Hi,
Can anyone tell me if there is an easy way to test if an ignition coil is faulty using a voltmeter/ tester as I have a couple of spare ones lying around. If so, which wires do I connect the tester to ? I've read in previous posts something about checking ohms. Sorry but I'm a complete novice when it comes to testing electrical components so any help will be appreciated.
Regards,
Glyn.
Top
 Profile
 Post subject: Re: Ignition coils
PostPosted: Sat Sep 08, 2018 6:34 am
Offline
Country: WALES
Have a look here
https://youtu.be/rRQ45lT2d3c
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Sun Sep 09, 2018 1:47 am
Offline
Cheers GTandcbr,
Thanks for the very informative link. I followed the instructions on the video but unfortunately my Haynes Manual doesn't give any numbers to check my results off, just says to contact my local Suzuki dealer if faulty coils are suspected. So I thought I'd post my readings here to see if anyone can tell me if they are ok or not.
Primary Readings as follows,
Coil 1 = 5.5 ohms, Coil 2 = 5.4 ohms, Coil 3 = 5.5 ohms.
Secondary Readings,
Coil 1 = 8.82 ohms, Coil 2 = 8.65 ohms, Coil 3 = 9.18 ohms.
All readings taken with plug caps removed.
Kind regards,
Glyn.
Top
 Profile
PostPosted: Sun Sep 09, 2018 4:48 am
Offline
Country: Germany
Suzuki 2-Strokes: GT250/380
Hi!
To measure the primary side, choose the lowest OHM measurement range. (e.g. max. 200 Ohm)
Then first, connect the test leads directly. The meter then shows the resistance of the test leads.
This must be subtracted from the primary coil measurement result.
For secondary coil choose range with maximum around 20 kOhm. (= 20000 Ohm)
Readings, may differ slightly, up to 10%
Denso coils: prim.:3.7 Ohm, sec.:9 kOhm
Kokusan coils: prim.:4.3 Ohm, sec.:12 kOhm
Assuming:
Denso-Coils,
secondary readings show kOhm,
resistance of the measuring leads wasn't considered,
your readings seem to be OK.
_________________
http://suzuki-gt250.de
Top
 Profile WWW
PostPosted: Sun Sep 09, 2018 5:59 am
Offline
Country: WALES
If you look here at specifications it shows the figures you are after
https://hvccycle.net/suzuki-gt380-gt550 ... 410-31010/
_________________
Top
 Profile
PostPosted: Sun Sep 09, 2018 8:00 am
Offline
Hi again,
Thanks for all the help. So it seems my spare coils may be ok to use after all.
Regards,
Glyn.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 6 guests
Jump to:
Suzuki2Strokes.com
