T250R
- Suzuki 2-Strokes: '71 T250. '63 Ariel Leader. '73 T500
T250R
On post 8, the wiring diagram there for the T500. That looks similar to mine on the 250? Could this be correct? Does the suffix T250R have any significance also? Thanks.
Some people say I'm a complete fool. Ah! But some parts are missing.
Re: T250R
The T250 wiring diagram is similar to the GT250 diagram but it doesn't have a voltage regulator.
- joethebike
Re: T250R
Thanks jabcd for your old post on wiring a Tympanium rectifier/regulator into a T350. Did my J model using your circuit diagramme and it worked out just as you said it would.
1982 Honda CX500 EC 275,700km
2005 Suzuki DL650 151,500km
Re: T250R 4 wire ignition switch wiring diagram.
Getting a little desperate now looking for one for my T250. Every one I've found so far is for the 6 wire ign' switch layout. Can anyone help me out please?
Re: T250R
Does your ignition switch connect to the wiring harness in the headlight bucket or under the gas tank?
Re: T250R
Sorry I didn't see your post. It's under the tank jabcb.
Re: T250R
Ignition switch part # 37110-15110 or 37110-31017.
NOS Suzuki part available for 85 GBP: https://www.discountbikespares.co.uk/ou ... GS750.html
A few aftermarket switches for about 20 GBP on the UK eBay using the search string “suzuki t250 ignition switch”
