T500 battery not charging.
Posted: Sat Jan 03, 2015 9:18 pm
I had a problem with the battery not charging some time ago and it turned out to be the voltage regulator was kaput. Fitted a spare and everything went back to normal. That was about a year ago.
Noticed the the indicators weren't flashing properly the other day so I checked the battery voltage, it was down to about 10.5 volts. Charged it up and the bike ran fine and the lights etc all looked good. Checked the battery voltage and it was 12.8volts with the bike stopped and 11.8 when it was running.
Decided to check the alternator.
Unplugged the alternator wires from the harness and rectifier. (Resistance of less than 1 ohm was expected)
- Resistance G/W to Y/G = 0.9 ohms
- Resistance R/G to Y/G = 0.8 ohms
- all wires to ground = open resistance.
Checked the AC output (expecting to see 35 to 40 volts) at 2500rpm:
- RG/YG = 30 - 35 volts
- YG/GW = 0 - 20 volts (values varying rapidly)
Given that the resistance values were OK I was surprised to see the output voltage was screwed up.
Any thoughts guys?
Any thoughts guys?
