I tested pairs of coils I have and came up with the following primary coil resistance:
T500R = 6.1 ohms each
T500J = 5.1 ohms each
T500K = 4.5 ohms each
I am debating whether to re-use the T500J coils on mu current restoration project and wondered what you good folks think? I want to re-use as much of the original parts as possible.
Does anyone know how the HT lead is fixed into the coil body? I don't want to try to unscrew it if it doesn't...
Geoff
T500 coils
- Fritz500
T500 coils
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
Re: T500 coils
Interesting trend in resistances.
The spec is 3 to 6 ohms. You should also check for secondary resistance & grounds.
See page 18 of: http://www.ozebook.com/compendium/suzi/suzidata1.htm
Posts on HT lead replacement:
viewtopic.php?f=20&t=6940&p=122391
viewtopic.php?f=2&t=8232&p=128746
viewtopic.php?f=2&t=5222&p=110899
- Fritz500
Re: T500 coils
jabcb,
There was no reading for the 500R secondary coils so I assume they are stuffed.
The 500J gave readings of about 20k Ohm, so OK.
Thanks for those links. Very helpful.
I'll do a practice replacement of a HT lead removal on the faulty coils.
Geoff
Geoff
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
