Wire harness repair/restoration
Re: Wire harness repair/restoration
Amazing! Great job! I just hope that I have a small amount of the patience required to get close.
By the way, what paint do you use for the black on the body.
Regards
"One slowly evolving GT500A"
Thanks for the tutorial on your technique. Did the plastic caps for the switches come right off? I have a T500 and the turn signal switch plastic cap will not come off and I don't want to break it.
Mike Nellis
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'04 Suzuki GSXR 1000 (racebike)
'00 Yamaha YZ426
'01 Yamaha Raptor 660
'85 Honda 250 Big Red
RV-6 Kit Airplane
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
Once again, here are Suzsmokeyallan's (corrected) instructions in printable form...
Regards
Thanks for that Roger but you need to remove the paragraph above the first photo, the other type of switch knob I was referring to about the attachment types with the clips was related to the T500 and not the GT750.
I'm having a bit of an issue getting the wires in the grades and colours I need for my harness upgrades posted earlier in this thread, and after looking around southern Florida as well as on ebay, I had to end up ordering them on-line.
Excellent, great job! Thanks.Roger486 wrote:Once again, here are Suzsmokeyallan's instructions in printable form...
Mike Nellis
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
Sorry about that... this should fix it... I thought that the information about removing the switches was useful, but I don't want to confuse people.Suzsmokeyallan wrote:Thanks for that Roger but you need to remove the paragraph above the first photo, the other type of switch knob I was referring to about the attachment types with the clips was related to the T500 and not the GT750.
PS - I have managed to find RustOleaum spray paint in New Zealand... so I can have a go. Now I need to find someone who can bead blast.
Regards
Thanks for the offer to look at my switch, here is a picture. It looks like the previous owner pushed the plastic on two far and it has rubber the housing. Or, he may have the wrong slider on there and needed to grind part of the housing away to get it to work, I'm not sure. My plan was to use some JB Weld to build up the area before finishing it off with the paint method you posted.Suzsmokeyallan wrote: mnellis:
The GT switch sliders are screwed on with a small counter sunk screw thats still available from Suzuki BTW, while some other models use a push on slider.
These other types usually have a plastic shaft design that meshes with two tiny visible slots on one side of the switch slider.
If this is the type you have you need to lift the slider evenly at the front and back while tilting it slightly to a side away from the slots so the little wedges on the shaft can slip past the slotted holes in the slider.
Why not send me a photo and let me confirm which ones you have on your bike.
Mike Nellis
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
See a photo is important, I thought you were talking about the light switch sliders when you're talking about the indicator switch slider. If it has no screw underneath it, its made on to the metal bar and you have to undo the bar itself from inside the housing and slide it out through the front of the switch.
For the rubbing issue repair the sections and make it smooth, then get a piece of thin clear plastic like the type you find in new shirt collars to stiffen them for presentation.
Cut a piece of the plastic sheet the same size as the knob with a slot to pass over the bar to fit between the knob and the switch housing. This extra piece now acts like a self lubing slider so the knob itself does not dig into the housing.
Good idea with the plastic sheet, thanks.Suzsmokeyallan wrote:See a photo is important, I thought you were talking about the light switch sliders when you're talking about the indicator switch slider. If it has no screw underneath it, its made on to the metal bar and you have to undo the bar itself from inside the housing and slide it out through the front of the switch.
Mike Nellis
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
That sounds like a great idea.Suzsmokeyallan wrote:See a photo is important, I thought you were talking about the light switch sliders when you're talking about the indicator switch slider. If it has no screw underneath it, its made on to the metal bar and you have to undo the bar itself from inside the housing and slide it out through the front of the switch.
Here you go. Simple instructions to follow!Suzsmokeyallan wrote:Roger can you add these images into the PDF file on the switches you have created so it helps with illustrations.
Regards
That pdf file update looks great Roger and the extra images give a better idea of the visual restoration process.
It makes me think that I could even have a go myself!!
Regards
Do you paint the insides of the switch bodies as well?
Regards
The interior gets painted during the process, but not intentionally. I'm more concerned about getting the edges and the overlap sections of the castings covered properly.
Too much paint on the interior could stop the parts from sliding back into their slots, so two light coats just to hide the raw aluminum finish would be perfect.
