T500 / T350 Oil Pump Seal Kit
What you have to offer the two-stroke community
Bloop2
Country: Ontario, Canada
Post by Bloop2 »
I have put together a complete seal kit for the T500 Oil Pump, includes the correct 3 O Rings and the 2 oil seals. The seals and O rings required for the pump are not available from a single vendor. I have spent about 5 months acquiring the correct seals and O rings for this kit. Offering this kit to board members for $15.00 US, includes shipping in the price for US and Canada members, for UK, Europe, Australia, New Zealand, overseas from NA, please add an additional $1.00 for postage. If you were to order these individually from the different vendors, you're cost would be in the $20.00 to $25.00 range. Ordering more than 1 kit? Additional kits are $13.00 each. Payment is by Paypal in US or Canadian dollars only. Please contact me via PM or email for ordering information.
Regards....Fred
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
rbond
Re: T500 Oil Pump Seal Kit
Post by rbond »
I have not checked yet, but are the oil pumps the same for years of T/GT500's? If so I would like a kit!
Bloop2
Post by Bloop2 »
There are 3 different part numbers for the oil pumps depending on year, the only one being unique would be the 68 Cobra, mostly a slight difference in the aluminum casting of the pump housing. The Cobra has a slight variation in the actuator arm and stop, and the end plate for the cams. There are other variations in the aluminum housing in the 69/70 pumps and then they change again for the 71 and up. The 76/77 pumps have the same part number as the 69/70. I have disassembled pumps for 68,70,72 and 74 and they all have the same size seals and O rings. So, it would safe to say that they all used the same seals and O rings.
Fred
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
phabbo11
Suzuki 2-Strokes: 72 73 t500
Post by phabbo11 »
I just fitted 1 of these kits and it's perfect.thanks fred for your time and effort!
Freds done a great service putting these together. I've got some on order as well.
Bloop2
Post by Bloop2 »
Thanks!!!!!
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
mike1161
Suzuki 2-Strokes: 1970 T350, 2012 Triumph Thruxton
Post by mike1161 »
I got the seal / O-ring kit the other day, and just finished installing it into the oil pump. Everything was perfect, thanks again for putting this together. By the way, my bike is a T350, and the pump is exactly the same as the T500, so this will work just fine for the T350 too.
Bloop2
Post by Bloop2 »
mike1161 wrote:I got the seal / O-ring kit the other day, and just finished installing it into the oil pump. Everything was perfect, thanks again for putting this together. By the way, my bike is a T350, and the pump is exactly the same as the T500, so this will work just fine for the T350 too.
That's really good to know, I wonder if the X6/T250 would be the same also?
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
Freds oil pump kits I had on order have arrived and are excellent, highly recommended.
Bloop2
Re: T500 / T350 Oil Pump Seal Kit
Post by Bloop2 »
Currently sold out, should have some more in a couple of weeks.
Fred
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
rbond
Post by rbond »
When you get some more kits made up, PM me! I really will buy one from you, it is getting closer to time for me to pull my engine and this will be part of the overhaul. Thanks, Robert
Bloop2
Post by Bloop2 »
Finally have a new supply, for some reason my order from the O Ring store went to Sweden first and then back to Canada, Thank you USPS!
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
Thanks for getting the oil pump kits back up for sale Fred.
Repeater
Suzuki 2-Strokes: 1974 T500 & 2007 GXS-R 600
Post by Repeater »
Thanks Fred! I also just bought the gasket
Still four available on eBay. Not from Fred but he said they are hard to find if you mess yours up.
:( Hi,Does anyone know the dimensions of the "V" oil seal fitted to the actuator shaft of the oil pump for the GT750A ? Apparently is a V type oil seal for a reason,designed to allow for movement & any misalignment in the shaft !
