Page 14 of 16
Re: My other bikes....even some non suzuki 2 strokes
Posted: Mon Apr 13, 2020 10:18 pm
by busa1300
Alan H wrote:You need a clear fairing so the frame can be seen. It's a work of art, is that.
Thank
The biggest problem with the modern era strokers is the bikes need fairings to hide everything.
As they developed more HP they also became quite complicated.
Water hoses. radiators, oil lines, fuel lines, powervalve cables, throttle cables, choke cables, wiring for air solenoids, and extra hoses for air and vacuum needs.... You can barely see the motor with all the crap necessary
Although Suzuki did build the VJ21 as a standard type bike for Japan.....but it is still pretty busy looking under the tank compared to the simplicity of an aircooled stroker.
I had thought long and hard about building it as a cafe racer instead of going with original paint and bodywork.....still not sure if I made the right choice.
____________________________________________________________________________________________________
Posted: Tue Apr 14, 2020 12:03 pm
It's your bike, so your choice is ALWAYS the right choice.
Posted: Tue Apr 14, 2020 7:44 pm
by busa1300
Alan H wrote:It's your bike, so your choice is ALWAYS the right choice.
The VJ21 SP project will be on hold for a while, until life gets back to normal around here.
Which will give me more time to second guess my decisions
Posted: Mon Jun 22, 2020 2:01 pm
by garry55
I had a TV250 Wolf. Never liked the seat unit, so I modified it to take a Mito unit. The motor was tuned to "naughty" spec and it's the bike I set my 250 cc fastest lap of Cadwell Park on.
for a modern water cooled twin it looks remarkably uncluttered under the tank.
Posted: Sun Jul 19, 2020 7:33 pm
by busa1300
Looks like a fun bike Gary.
I had started to collect some Wolf gauges and had been searching for the headlight and brackets.....then decided to keep it with full bodywork.
Posted: Wed Jul 22, 2020 1:54 am
by garry55
It is a much more comfortable ride with the higher handlebars. The single disc is more than adequate too (with race pads fitted).
It weighed next-to-nothing and kicked out 58bhp at the rear wheel (on the dyno).
One of the few bikes I wish I hadn't sold on.
You have got me looking for another now....................
Posted: Tue Oct 27, 2020 4:49 pm
by busa1300
Decided stock bodywork
Finishing up paint work, and collecting bits to get the engine back together for the VJ21-SP....but not much to show for all the time that has passed.
Test fitting Lectrons for cables
Veronesi intakes to adapt the 38mm Lectrons in a upright position
Posted: Fri Nov 13, 2020 1:38 am
by Hush
I rebuilt a very dead and neglected GT250K as a run-up to doing my present GT550L and I learned heaps from the little beauty.
Posted: Sun Jan 24, 2021 5:06 am
by busa1300
Posted: Fri Feb 05, 2021 4:52 pm
by garry55
what is the difference between the Dyna DC11-1, DC11-2, DC12-1 and DC12-2 coil packs?
Posted: Sun Feb 07, 2021 9:47 am
by busa1300
I looked on the website and it is a bit confusing.
The DC12-1 looks like a pair of single output coils
DC12-2 is one single output coil
DC11-1 is a pair of dual output coils.....
I think that is how it goes....???? but definitely not 100% sure on any of it.
You still have the VJ23...?
Looks like Suzuki has cut off the supply line on some major parts to them...
I have a spare engine for mine, but no new bits for another rebuild
Posted: Sun Feb 07, 2021 2:07 pm
by garry55
thanks for that info - guess I will buy the same as you have (DC12-1) and hope for the best.
Sold both VJ23's a couple of years ago. They are OK, but a bit sterile compared to the VJ21. Just my opinion, of course.
Posted: Mon Feb 08, 2021 2:56 am
by gammakeith
Yes, "modern" 2 strokes are a bit busy under the fairings but some engines just should not be covered up
I've got my RG500 partly stripped for some routine maintenance. I'm glad I did as one disc valve cover was starting to delaminate. Looking forward to doing some miles this coming year.
Keith
Posted: Fri Feb 12, 2021 6:37 pm
by busa1300
The RG500 looks more user friendly to work on than my RZV500R.
I wish I had one of both to know for sure
Posted: Sat Feb 13, 2021 2:42 am
by gammakeith
I have some friends who have worked on both and they would certainly confirm the RG is much easier to work on. After all, it is very closely based on the race engines. They do need treating gently though and there are several pitfalls. For example, if you look at the pics you will see the oil lines. They are so easy to trap when putting the carbs back.
Keith
