my 75/4
Photos that don't really fit in the above catagories.
my 75/4
four 1975 Suzukis
Re: my 75/4
Nice collection. Really nice 550.
Are the wheels on the gray bike tubeless or tubed? The est I have of those GS wheels don't have the bead required to hold a tubeless tire, so I had to buy tubes to slip inside the tires. That theoretically reduces teh speed rating from 130 to 118 but I hardly see that as a problem.
Re: my 75/4
Nice collection :up: I didnt know you are the new owner of Red Zone ?
Re: my 75/4
Yes.
Coyote did excellent work on RedZone. The only mod I did was to switch to bar end mirrors.
Also got the T500 from a forum member a few years back.
I upgraded it to a modern rectifier/regulator & H4 headlight.
The side stand bracket broke off & I had it welded back on. Also had the typical leaky petcock problem.
Has a bit too much fork spring sag -- am undecided on what to do about it.
The red GT750 has about 700 miles on a complete motor rebuild.
I got the gray GT750 after the PO did all the updates but hadn't sorted it out.
Had Avon RoadRiders installed but I don't remember if it has tubes. I haven't had any problems with air leaks.
Have just recently finished the sorting.
Don't know what kind of pipes the gray GT750 has.
Its gutless below 4k & makes good power 4.5k & up.
Its a bit annoying. Lots of hills where I live. If you pull out going up hill from a stop sign, it slowly accelerates while you wait for 4k rpm.
Am thinking about changing the gearing.
Flywheel
Suzuki 2-Strokes: 1974 GT185
Re: my 75/4
Post by Flywheel »
I've seen some of Jabcb's collection, all very clean machines. :up:
Re: my 75/4
We need to put together a Pa. gathering :up:
Re: my 75/4
Suzukidave wrote:We need to put together a Pa. gathering :up:
Good idea. :up:
Updated gray GT750 with Jemco exhaust.
Re: my 75/4
That looks great :up:
