Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Apr 25, 2019 8:56 am
Post new topic Reply to topic  [ 184 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
Author Message
PostPosted: Wed Jun 13, 2018 6:20 pm
Offline
Bikes owned: RGV RGV RGV RGV ......
Dyno time... :mrgreen:
The dyno shop owner said his dyno has always read a bit low to several other dyno's in the area. Another shop has a dyno (same dynojet 250) that consistently reads 10% higher.
He has done several back to back/same day dyno runs to prove it to other customers....
With that said, my bike pulled a 60.14 at 12000, with 27.04...best run...
Needs a bit of tweeking in mid range as it appears that it is surprisingly slightly lean. I'm thinking air solenoids should make it as close as I will need.
I ended up running 25% 110VP racing gas and 75% premium.
I am finally satisfied, and I can now move on....
_________________
MY TWO STROKE ADDICTION
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
GT 750 J....sold.....
GT 750 long term cafe project
SX-R 800
KD 80
JR 50
RZV 500 R....on the bench
Top
 Profile
PostPosted: Thu Jun 14, 2018 4:48 pm
Offline
Nice graph and great results. Now to richen up the mid range to get a little more HP in first. Glad to see you ended up at Valley Racing.
Top
 Profile
PostPosted: Fri Jun 15, 2018 11:54 am
Offline
:up:
I'm going to use my Zeel and play with my air solenoid settings and see if I can do that. Might delay my powervalve another couple hundred also to see if I can straighten out the line near the top.
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
PostPosted: Fri Jun 15, 2018 7:25 pm
Offline
It's so long ago that I'm not sure I remember all the details but I want to say that when we retarded the PV opening, the graph took an even sharper up turn and had a more pronounced peak.
Our best result was just a touch over 65 on a blueprinted motor. Wish I still had all that data but it went with the bikes to the new owner.
What fuel did you run that on? Really high octane is safe but tens to burn slower and that can lose you a little power. I'd like to see that motor running U4.4 back to back against any other fuel.
Top
 Profile
PostPosted: Sun Jun 17, 2018 8:33 am
Offline
Ran about 25% VP110 and 75% premium 93....
Timing is at the edge so I need more octane than 93 gives when riding hard on the backroads.
I think I understand where to dial in the Zeel for the powervalves and air solenoids...but thinking is not the same as knowing...
I have the Zeel / Sugaya R2 ignition box parameter info and the A/F ratio / dyno charts...
I can change them, but it's running at a point now where seat of the pant's might not tell me if I'm going in the right direction with small increments
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
PostPosted: Mon Jun 18, 2018 6:37 pm
Offline
Box of 24 stainless steel valves showed up today....
Making arrangements now with a machine shop to get them fitted to my spare head sometime after I get back from Vacation in July.
Pulled my pipes off the VJ23 to clean them up and get them resealed, as they were leaking just a bit when run up to redline.
Might need stiffer springs...?
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
PostPosted: Tue Jun 19, 2018 9:23 am
Offline
Country: England, UK
What engine are the 24 valves for?
Top
 Profile
PostPosted: Tue Jun 19, 2018 1:55 pm
Offline
I need to redo the head on my CBX.
I went through it when i put a new J+E bigbore kit in and cleaned up a head and soda blasted everything.
Then lapped all the valves and put things back together with new seals....
But after about 1000 miles, one of valves had started to leak and I have lost most of my compression in a cylinder. ... :cry:
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
PostPosted: Tue Jun 19, 2018 7:02 pm
Offline
Bikes owned: T500R (now), T500M (40 yrs ago)
Damn. Look at all of them bits.
A reason to love your 2-stroke. Mine runs with only 9 moving parts. :P
Top
 Profile
PostPosted: Wed Jun 20, 2018 4:35 pm
Offline
My RZV has a few more parts moving than that.... :mrgreen:
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
PostPosted: Wed Jun 20, 2018 5:24 pm
Offline
Well, the RZV is a bit more modern than my T500.
I usually go with saying 9 moving parts - 2 pistons, 2 conn rods, crankshaft, 2 sets ignition points, and 2 slides in the carburetors. That's all you need to run the engine, and control its operation.
Seeing all those valves, springs, lifters, and all the other bits reminds me why I love the 2-stroke so much.
Top
 Profile
PostPosted: Sat Jun 23, 2018 10:56 am
Offline
So it was a faulty valve? or valve seat? on the CBX. Nice bike. I would love a CBX. I own one in my fantasy garage.
Top
 Profile
PostPosted: Sat Jun 23, 2018 7:35 pm
Offline
I have a genetic condition that makes me look for complex designs with parts that are a challenge to find or fix.... :mrgreen:
But the satisfaction of finally getting it right makes up for all the trouble.....at least that's what I tell myself.
Not sure which it is, but the spare head I have will get all the valve seats redone to match the new valves, so I won't have to worry about the issue anymore. It was a 20,000 mile head I cleaned up and put on my CBX after I put the bigbore in. I'm guessing it is a seating issue, as I do have some compression...just not all the compression it should have. Air was coming out of the intake port when I did the leakdown.
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
PostPosted: Sun Jun 24, 2018 12:13 pm
Offline
Could have been a tight tappet or too lean mixture burnt the valve out.
Top
 Profile
PostPosted: Sun Jun 24, 2018 6:45 pm
Offline
Valve clearance was all good, and plugs all looked more on the rich side than lean....
Not sure the reason yet, head wont come off till I have the other one ready to put on....unless I bent one over reving..... :oops:
_________________
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ22 N
RGV VJ23 T
RZ 350
SX-R 800
KD 80
JR 50
Top
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
cron
Suzuki2Strokes.com
