32 round slide gt550
aslsmm
Country: us
Suzuki 2-Strokes: 73 gt 750 74 gt550
Post by aslsmm »
hello, i talked with eric K about a 550 build. i have a set of 32 mm round slide mikuni carbs that are brand new. i was wondering if anyone has mounted these carbs to a 550 before? they seem rather large. i cant get them to fit.
Re: 32 round slide gt550
That would be quite a stretch with stock intake rubbers.
In Reality I think that a 550 has enough carb area for even quite a wild motor. That's not to say that more can't work better but to put it into perspective, a 60HP RZ350 twin gets on fine with a pair of tiny 26mm carbs. The 550 has 28mm carbs and the analysis we did seems to suggest that 28 on a small triple is enough for 80-85HP.
The 750 came with 32mm carbs and the old suggestion was to fit them on a 550 as an upgrade but I'm not convinced there are any real advantages for a street motor.
aslsmm
Country: us
Post by aslsmm »
ok, he didn't really suggest them, i said "hey i have these brand new 32mm carbs would those work?" and said, "those will be perfect.
i am going to fiddle with it. i just gave away the stock carbs to a friend of mine.
Well in that case, they would probably be perfect. Use radiator hose for intakes or machine off the stubs and fit regular Mikuni type inlet rubbers.
aslsmm
Country: us
Post by aslsmm »
thats a good idea. thanks rich, always full of good ideas.
aslsmm
Country: us
Post by aslsmm »
so i got them to squeeze in there with the original boots. its tight but it should work great. thanks for the help guys.
